Results 1 to 3 of 3
Thread: Roof loom help
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Default Roof loom help
    I've posted this in the 'How2 Discussion" forum but for a wider audience I apologise for putting it here as well...
    I've just got hold of auto-dim mirror, rear light, illuminated visors, rain sensor and complete loom for £35, which I feel is a right result. Anyway, I have just stolen an hour's time from work and been down to have a look at sussing out how to go about getting the loom into the roof space with a view to then using the tip about using plastic packing cable to guide the various connectors to where they need to go and then pull them through the relevant hole in the headlining. Some questions for all your learned members:
    1. Is it absolutely necessary to remove the visor holding clips, or will the headlining drop enough along the side of the car to slide the loom across to the centre where I'll pull it through the main roof light hole?
    2. How does the clip holding the trim to the inside of the C-pillar undo? I don't want to knacker it and it seems fairly well set.
    3. To fit the rear roof light I suppose that the headlining needs to come down quite a way to allow access to the 'recess' where the light fits. From my quick look the headlining is again very rigid across the boot top and along the side of the car so how much force is required or are there any tips to make this easier? Is there velcro involved? Alternatively can I guesstimate where it should go from inside the car?
    4. Will the rear light fit in without the metal surround that should line the hole (it came without this) or will the weight of the light make it drop out?
    Thanks for reading this far down, all replies gratefully received...
    Full Member spennny's Avatar
    Blantyre
    Hello Mate,
    Am from Farnborough also , Where bouts are you ?
    1) You dont need to remove the visors, maybe just the passenger side
    2) C Pillar , is that the one at the front ? lol, You have to pull the plastic clips out at the top, where the airbags sign is
    3) There is a template knocking about
    4) Yes it will fit without it
    If ya need a hand gimme a shout
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    North Camp. You done this? If so I might take you up on your offer, I'm cr*pping myself I'll ruin the headlining, or something else.
  1. Roof loom
    By Rob h in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2012, 12:14
  2. Roof Loom
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 15:40
  3. Roof Loom
    By bigboynigs in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2009, 19:14
  4. Roof Loom
    Last Post: 8th January 2009, 20:30
