Thread: How do i get to the back of 12v socket
    Oct 2006
    Suffolk
    Default How do i get to the back of 12v socket
    OK i need to get to the back of the 12v power socket the one at the front of the car ( ciggy lighter )
    How do i get to it, tried to remove ashtray base but couldnt do it ?
    Any tips, this is so i can power my Road Angel
    Note this is a Signum 2006 model
    [Ex]Admin Duncan's Avatar
    http://forum.vectra-c.com/showthread...ter#post186831
    Wonderful thing that search feature!
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Yep, but he possible has the same problem as I have: ashtray won't move
    Siggyman: shout if you manage to remove it
    Is that a difference on the facelift then? How do you get to the ODB II (Tech 2) socket then?
    Oct 2006
    Suffolk
    Quote Originally Posted by sig63 View Post
    I tried this but didnt want to pull too hard and break it !
    Yes the Tech2 socket is visible when the ash tray bit is lifted out but the ashtray lid frame is held in firm somehow
    Feb 2006
    Dorset
    It will unclip , take the inner section of the ash tray out so you can grip it and pull stright up , make sure you have removed the gear surround as well.
    member of the smoke patrol 230bhp+
    Quote Originally Posted by DennisTheMenace View Post
    TO THIS TIME IN NEEDING IT OUT I BOTTELED IT AT SAID TO MYSELF IM GOING TO BRAKE THIS IF I PULL IT ANY HARDER
    SO IT STAYED IN
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If you don't have a rear lighter socket then you may have the wiring for it still. Mine has the live wires inside the centre box and that would be a much better place to take a feed from.
    Mine doesn't have the arm rest so it's quite easy to remove, just three screws but I've never attacked an arm rest one.
  1. socket set
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2012, 01:45
  2. USB socket
    By rockonoli1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 13:33
  3. Power Socket in back of vectra CDTI 2006 facelift
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 12:55
  4. 12v aux socket
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 20:58
  5. USB Socket/Aux In
    By armstma1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2007, 21:18
