Thread: maf
    Dec 2011
    northamptonshire
    Default maf
    hi a question dose the vectra 2.0 dti 2004 maf sensor have the thin wire between the two prongs?? keep getting p100 and p400 random error codes took side of egr and seams to open and close fine. took maf off and can see the to prongs but dont seam to be a wire joining them.....
    exeter
    have you clean the inlet manifold as mine kept giving me p400 error and i cleaned the boost presure sensor and egr but i was still getting the code coming up so i cleaned inlet and since then i hav'nt had any trouble with it . i could'nt take apart my maf it was a big sealed tube . i could see the sensor but it was covered by some sort small filter so i left it and my egr was electronic so all i could do was clean it .
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Mine's the same, not sure if it's supposed to be or not but on other MAF's there's usually a thermic resistor there for air temperature. I'm wondering if mine's disappeared too
    Dec 2011
    northamptonshire
    yes cleaned it and egr and map and maf cleaned with break cleaner. if i look into the maf tube you can see to metal prongs coming down at the top where the maf sensor is conected but the two prongs dont seam to be conected????? on all videos the utube has regarding maf sensors the two prongs are conected and when the engine runs the air flow cools the metal tread that conects the two prongs and there for vereates the air and fuel mixture... im not sure if the vectra works in this way. due to the videos on utube are on older cars. my car will run fine on tic over and the fault is tempremental it can go 3 4 days with out a problem then one day where the spanner light comes on all the time giving me some times p400 some times p100 and some times both p100 & p400
    Dec 2011
    northamptonshire
    its a nightmear as im reluctent to fork out £350 for a egr or £130 for a maf and it dose not cure the problem. i have renewed all vac pipes to inlet turbo and egr. and it dose my head in that its so tempremental
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Does this help you with testing the MAF http://www.autoshop101.com/forms/h34.pdf ??
    If the engine is hooked up to a diagnostics, most software can energise, run and test the EGR to determine if it's working or not.
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    Hi all, you can pick up OE maf for about 50:00 on ebay ,just put the number on your unit,the MAF erodes with all the air flowing over it,you can remove the centre unit by undoing the screws on top and wiggle it out it has an o ring ,but be carefull,all you should use is mild detergent or alchohol based cleaner. Hope this helps.
    Dec 2011
    northamptonshire
    thanks for all the help. dose the maf have a thin bit of wire that conects the two terminals where the air flows????????
    Nov 2011
    I've robbed the air temp sensor off an old spare Bosch MAF i had in the garage, and put it in the empty prongs of my Vectra MAF. Hey Presto!! It's registering an intake teperature now on the program beginning with "O"
    Took it out for a drive and the diference is instantly noticeable, and the error code has not returned since
vectra p100 code
