Results 1 to 2 of 2
Thread: V6 CDTi problems and cures ?sticky?
    Jun 2011
    Elland
    Default V6 CDTi problems and cures ?sticky?
    Maybe of some use to people, but here are some problems and solutions that I've had with my V6...
    Squeaking / chirping sound from bottom left hand side of the engine(standing at the front of the car looking at it). Sound worse at idle and cold. Problem: worn aux belt tensioner cured by replacement.
    Sooty tailpipes on DPF car (facelift model) - probably shot DPF filter, but car passed emissions test so I did nothing and kept the £1000 in my bank, thank you
    Misfiring / lack of power under load / car will not rev under load. Error codes can be thrown (scary) e.g. injection system failure and the one associated with SCV failure. Problem: air in the fuel system caused by leaking joints in the fuel pipework (there is no lift pump on the V6). Observation: on opening the fuel filter canister, it is half full of fuel. Test: top the fuel filter housing up and the problem temporarily goes away. Solution: replace engine bay fuel pipework and fuel filter housing. I used flexible marine grade fuel hose (because I had some), good quality jubilee (worm drive) clips and a Racor 2 micron R20 marine fuel filter housing, scrapping all OEM pipework and fuel filter. The replacement filter was fitted where the original had been and it bolted through the bulkhead: there is access to the void behind via the scuttle tray access flap.
    Poor low end response, engine seems a bit 'all or nothing' around 2000 rpm. No idea why, but the problem went away after I fitted a DTUK green box
    Feel free to add....
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Nice little list mate. Should be useful to people.
  1. Replies: 71
    Last Post: 23rd July 2017, 14:41
  2. 1.9 CDTI Problems
    By kai21 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2011, 11:27
  3. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  4. Got ear ache......any home cures?
    By bobby-tupper in forum General Chat
    Last Post: 11th January 2009, 17:16
  5. Hangover cures..................
    By Mrs D in forum Comedy & Humour
    Last Post: 19th December 2006, 14:37
