Thread: Y30DT - Overfueling during hot startup?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Y30DT - Overfueling during hot startup?
    Ever since I bought the car almost two years ago I noticed that when I start the engine when it's fully warmed up and it's been sitting for less than 5-10minutes, it will turn over SLOWER than when it's stone cold at -5°C. It will start with the same amout of turns and won't sturggle to fire...just seems to be slower. Battery is good.
    On a cold morning it won't smoke at all, but if warmed up it will kick out a puff of soot when I start it...that's why I think it's overfueling.
    The car now has a Steinbauer Tuning Box fitted, which if anything is making the car smoke less...
    Suggestions anyone?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I also had the puff of smoke on a warm start up but only from the left tail pipe . This seems to have stopped since I cleaned the air temperature sensor, the one in the inlet manifold close to where the EGr is located. http://vectra-c.com/forum/showthread.php?t=152973
    I've not noticed any difference in cranking speed though.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Does it reach temp ok? Does it run ok otherwise?
    It's all about the variation between engine block temperature and ambient temperature
    On older engines this was controlled from the fuel pump, on the x30DT family this is controlled from the EMS
    There are also other factors, such as oil viscosity and battery condition
    At -5'C (cold engine block temperature) I would expect the engine to turn over at slightly higher revs, but it may sound like it is turning over slower as there is more noise
    Equally, I would not expect to see any excessive black smoke (full combustion)
    At 25'C (warm engine clock temperature) I would expect the engine to turn over at normal revs, as a result there will be very little variation in sound
    I would also expect occasional black smoke as the engine is not making any changes so any fuel previously in the system may not be fully combusted as the glow plugs may not be required (even though the light appears during start up sequence)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It reaches temperature just fine and stays at 87°C most of the time.
    I won't try to remove that sensor mate cos the manifold has a thick soot crust on its walls...I don't want any big carbon piece to get sucked into the cylinder...
  1. startup issues and some more
    By james walker in forum Engine & Drivetrain
    Last Post: 14th September 2011, 08:53
  2. smoke from cat on startup
    Last Post: 29th August 2011, 20:17
  3. Startup
    By treasure22 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 17:55
  4. Idle on startup
    By Redviper in forum Engine & Drivetrain
    Last Post: 12th January 2010, 10:20
  5. EML On at startup
    By Thebug in forum Engine & Drivetrain
    Last Post: 6th November 2009, 17:34
