Thread: Changing 3rd brake light
    Apr 2011
    Londonderry
    Default Changing 3rd brake light
    Hi, I have an 03 Vectra Hatchback and I have just purchased a tinted 3rd brake light, but I have read differing reports as to how to remove the existing red one, some say you remove it from outside, others to remove from inside. I was wondering if anyone can shine any light on this for me? thanks
    Regular Member VECTRA HEAD's Avatar
    Derry
    Ryan i changed mine a while back,my car is a saloon model,i got an old credit card and cut it into 6 pieces,on the new light you`ll see that there is 3 metal clips at the top and 3 clips at the bottom of the light.Wedge the pieces of credit card in between the light(FROM THE OUTSIDE) and the rim of your bodywork and carefully ease the light out with a small screwdriver,its a bit fiddly but it will come out(just mind your paintwork),then just change over the power connection and push in your new one,i did mine in about 5 mins.HTH
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Can it be done by removing the lining on the inside of the door?
    Regular Member PANDY 3.2 V6's Avatar
    sunderland
    Quote Originally Posted by MrDerv View Post
    No it just reveals a metal frame when you remove the trim, you cant get at it from the inside
    Nov 2011
    Okeydoke! Just got to find one now
    sheffield
    pre 54 reg can be removed from the inside, but you have to drill 3 holes to reveal the allen key bolts, after 54 reg there is no frame covering it, and no allen key bolts either, so from the inside you can just removing them by pressing the clips together with your fingers.....
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by VECTRA HEAD View Post
    Exactly how I did mine on my old saloon. Old credit card cut into six bits, jam them in behind the metal clips from the outside to release them and it should just pop out.
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Hi, does anyone have one of these going? I recently changed my rear lights to clear indicator lens ones and want a clear/smoked 3rd brake light to go with it.
    Carl
  1. Changing brake discs?
    By amen in forum Handling & Braking
    Last Post: 16th July 2012, 20:33
  2. Changing Front brake Calliper
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 22:44
  3. Changing rear brake pads
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2009, 14:14
  4. Changing brake pads
    Last Post: 26th November 2008, 17:58
  5. Changing brake pads
    By dutluk2001 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 21:06
vauxhall vectra c third brake light how do you get it out www.vectra-c.com
how to replace third brake light vectra c
