Thread: Smoke in my engine bay - oh no!
    midlands
    Default Smoke in my engine bay - oh no!
    Hello
    I have a few issues with my 2004 120cdti signum.
    When the turbo kicks in it now hisses instead of a nice whistle like it used to!
    Looking today in the dark through the torch light i could see smoke in the engine bay - not much though!
    Now she has started smoking when the my foot is off the accelerator pedal. - not all the time though and the exhaust gas from the back is very hot (hand 20cm away and its too hot to hold there)
    I have no loss of power (not that i can tell) but do have a smell of fumes in the cabin when started.
    Any ideas?
    Thanks in advance
    Steve
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Split turbo pipes or damaged Turbo intercooler.
    If you have a leak from one of the turbo pipes then you have less gas going out of the exhaust which could make it hotter
    Regular Member Craig1985's Avatar
    harwich essex
    Is the 120 the same design as the 150? My 150 had a crack in exhaust manifold and was blowing/hissing. Ment a new turbo as the turbo and manifold are one unit on the 150.
    Try sprinkling some talc powder down the front while someone revs, you will see the talc blow from where leak is
    harwich essex
    harwich essex
    midlands
    Cheers - would the above cause smoke though?
  1. Help smoke from engine
    By Sway in forum Engine & Drivetrain
    Last Post: 27th January 2013, 18:46
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Smoke from engine
    By elite_150 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 22:26
  4. Smoke From My Engine
    By Keith01 in forum Engine & Drivetrain
    Last Post: 10th March 2011, 23:01
  5. smoke and engine judder/lag
    By phiniasfreak in forum Engine & Drivetrain
    Last Post: 27th April 2009, 13:33
