Results 1 to 10 of 14
Thread: vecra speedo/revcounter
    Stoke on Trent
    Default vecra speedo/revcounter
    My 55 reg vectra s dash is not working no lights speedo/ rev or warning lights any ideas as to what thye problem is please.
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Have you got anything lit up? Ecu light at all?
    Could be cim module or actual dash binnacle itself, check my thread history for ones I have started called "dashboard is kapput"..... Had this problem last year.
    I thought it was cim at first, but turned out to require a new dashboard binnacle assembly.
    HTH
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    There also some fuse to check, 17 & 26 on the passenger side of the dashboard, even if they look ok, remove and replace or swap for new ones, some people are lucky and this solves it...
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Disconnect the abs plug under the bonnet and clean it with some wd40
    Regular Member Mopar Man's Avatar
    herts
    Try disconnecting the battery for a couple of minutes, worked for me.
    Jan 2010
    Australia
    Hi
    Had the same problem until the dash instruments stopped working completely. Electronic technician found the data connection on the dashboard loose. Re- located and re-soldered data connection, no problem experienced for 30k travelled. Fingers crossed.
    VIP-Member ianwat23's Avatar
    Gateshead
    Vehicle : Vectra Sri 120 navi
    Trim : Sri
    Engine : 1.9 cdti 120 bhp
    Mileage : 38550
    Hi there I have this fault also, but I have the orange engine warning light come on with the ignition but once car starts the light goes out.
    All the lights and wipers still work so not sure if it will be the cim, hoping it will be an easy fix.
    The car has only 26k on the clock so its not as though it has been round the clock, the radio went funny at first then came back on. When I came back to the car and started it the speedo unit was not working.
    Is there a way of doing a diagnostic on the car to find out the fault???
    Any help would be useful.
    Quote Originally Posted by ianwat23 View Post
    I have the orange engine warning light come on with the ignition but once car starts the light goes out..
    That's what the emmisions fault light is meant to do (the one that looks like an engine).
    The car/spanner light however remaining on until the engine is running means a stored (but not current) fault code is present.
    Unless you meant the car/spanner light?
    Jun 2012
    Thamesmead
    I have had this problem on my 54 plate and got it sorted at the weekend the connector on the clocks is dry soldered and needs to be re done it takes about an hour but clocks need to be stripped to the board and then the needles reset and the problem will be sorted
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you get nothing from the CIM, then it could be Fuse No' 10 at the end of the dash
    Fuses 17 and 26 are for instruments and display, so if these are faulty, the display will not work properly.
    A common issue - could be a faulty battery, loose battery connection or faulty alternator.
    As mentioned above, the instrument can be faulty - dry of faulty solder joints on the connector.
    Also ABS plug pins can get dirty causing some instrumentation / CIM module issues.
  1. Vecra c wont start
    By markmc68 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2010, 18:24
  2. Pictures of new vecra 1.8 VVT engine
    By videodoctor in forum Quick Photo Album
    Last Post: 7th April 2007, 17:32
55 plate vauxhall vectra 1.9 cdti where is the fuse for the speedo
