Results 1 to 10 of 22
Thread: Safeguard Check.
    In a house
    Default Safeguard Check.
    I am getting the dreaded "Safeguard Check" message on the display every time I turn on the ignition.
    It's a 1.9 Vectra C SRi XP estate, I've had the Opcom diagnostics on it and have looked at the "Vehicle DTC Information" and it is not showning any fault codes that are alarm related.
    I've tried setting the alarm whilst still inside the vehicle both with and without the internal sensors activated and all seems to working ok.
    (Sensors detect movement and activate the alarm when active and allow movement / do not active the alarm when disabled)
    Since I bought the vehicle going on Three years ago the alarm has given me no trouble at all, however I have recently had a couple of false alarms within days of one another and then a couple of days later the aforementioned message started appearing on the display.
    Any help would be much appreciated.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    just a question ..have you got dogs ????
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    reason I ask is because they are know to break through the connectors on the rear window sensors with their claws . there are several threads about it ..if you do a search .
    Have you recently swapped keys?
    Do you still have both keys?
    Try using the other key
    Once you are in the car, do NOT insert the key into the ignition
    Switch the stereo on
    What message appears on the display?
    Now insert that key into the ignition
    What message appears now?
    Start the engine
    Is there any change?
    In a house
    Quote Originally Posted by soulman View Post
    No, no dogs, I've had a look at the traces on both the rear off and nearside windows and they look fine.
    I've also checked the spade connections behind the interior trim to both windows and again, all appears to be ok.
    In a house
    Start the engine
    Both keys are original and the same happens if either is used.
    Switch the stereo on = Normal display. (No Message)
    Insert key into ignition (Without turning key)= Normal display.
    Start the engine = "Check Safeguard" displayed on screen.
    Note: I didn't turn the key once inserted into the ignition as the instruction states "Insert key into ignition"
    Engine : 1.9 CDTi
    Quote Originally Posted by Saxman View Post
    I am getting the dreaded "Safeguard Check" message on the display every time I turn on the ignition. I've had the Opcom diagnostics on it and have looked at the "Vehicle DTC Information" and it is not showning any fault codes that are alarm related.
    You need to go into the different ecus and look for the codes in there but cant remember which ecu you need to check (I think its the REC ecu).
    In a house
    Quote Originally Posted by lee gsi View Post
    Done that.
    If you select "Read vehicle DTC information" using Opcom it will read each control module and show if there are any fault codes stored and which module they're stored in.
    For any fault codes stored you would then simply go to the relevant control module to read exactly what the fault code is.
    As per original post, there are no alarm related DTC's stored.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    does your alarm sound as normal ..?? or are they your horns ?? if so maybe your alarm siren has been disconnected ..
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    maybe you can fix mine tomorrow then
  1. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  2. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  3. Check Safeguard
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 10:25
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2008, 19:31
