Thread: AFL Issue's
    Regular Member shan's Avatar
    Default AFL Issue's
    I have a problem with my AFL's on my facelift siggy.
    The dash light comes on saying there is a fault.
    The headlight's swivel and level out when first switched on fine.
    It looks like the NS is pointing to far over to the left.
    One question is How/What tells the headlights to tilt/turn ?? I have heard there is a sensor mounted somewhere on the car, but i'm not sure where at.
    I think the problem lies with this sensor.
    Any idea's anybody.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You have 2 level sensors mate fron and rear nearside to determine tilt and the CIM in the steering binicle that does your steering angle I have had both fail and replaced do your indicators cancel? If not its your CIM But it could be the light unit itself you need a code read to tell you what the fault is
    Glen we should be able to read the codes at the Chop Shop later today buddy !!!!!
    Well after all that. It's sorted.
    Just adjusted the main beam lamp and it has cleared the fault. No issue's on the run home.
    Nice one.
    Oct 2010
    Finland
    Quote Originally Posted by paulhb View Post
    Where are these level sensors located? And what they look like?
    Oct 2010
    Finland
    Quote Originally Posted by vos View Post
    Found these(click pictures to get them open):
    https://www.autonvaraosa.fi/ajovaloj...235_19236.html
    Part numbers:
    Front 24417125
    Rear 93186514
  1. 2.2Dti Fuel Pump issue's?
    By sigtim in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 21:48
  2. ABS issue's
    By stig30 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 00:39
  3. Driveshaft issue's 2.0T??
    By Steven in forum Engine & Drivetrain
    Last Post: 13th February 2008, 17:28
