Thread: Swirl bar
    Aug 2010
    Derbyshire
    Default Swirl bar
    Have read on various threads that the swirl bar can become detached and therefore become useless. What I want to know is can I pull mine off, as mine is still attached and be able to push it back on again. In other words is it permanantly fixed or a push on pull off type of part.
    It looks like it all still works down there just want to clean things up around that area and would be easier with the swirl bar removed.
    BTW it's the 150 CDTi
    Mick
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    personaly i wouldnt pull it off as you might wear the joints out which could meen it will keep falling off.
    When you say clean things up,do you meen its oily round that area? if so the swirl pots are leaking
    Aug 2010
    Derbyshire
    Quote Originally Posted by justin32 View Post
    Yeah it's a bit oily down there, the car runs great and swirl bar still attached but a bit floppy.
    Is it about to drop off? And can the swirl pots be fixed (leaky) or is it a new manifold?
    Mick
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Squirt some soapy water down onto the top of the flaps. Start the engine, if it bubbles up, it's new manifold time.. (well, you can start planning atleast)
  1. Swirl bar
    By 1 hammer in forum Diesel Engine related
    Last Post: 24th October 2012, 21:58
  2. swirl bar off
    By vectraross in forum Engine & Drivetrain
    Last Post: 20th August 2012, 12:12
  3. Swirl Bar
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 29th February 2012, 20:14
  4. Swirl x
    By dannyp in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 17:59
  5. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
