Results 1 to 10 of 14
Thread: 3.0 V6 CDTI totally dead.
    Paris
    Vehicle : Pre-facelift Vectra V6 3.0 CDTI
    Trim : SRI
    Engine : Y30DT
    confused 3.0 V6 CDTI totally dead.
    Hi All,
    My 2004 3.0 V6 CDTI has been SORN for the past eight months as my company has provided me with a string of (fairly dull) cars, however I'm moving house and need to get it MOT'd and back on the road. I've been starting it fairly regularly while it's been sat on the drive, although admittedly not as regularly as you should, but when I've gone to start it this morning I've found it to be pretty much dead... I'll make a list of what I've done rather than write a long tale of woe:
    - 1st attempt to fire up ignition: Dash lights came on but got a bunch of click-click-click sounds from the engine compartment (alternator presumably?). Thought battery might just be flat as the headlights were fairly dim when I switched them on.
    - Hooked battery up to the girlfriend's car with jump leads and let it charge for a good 20 minutes.
    - Attempted to start engine but still got the clicking sound and after a couple of attempts to fire it up the electronics such as the dash lights and info display started flickering dimly and eventually went out, suggesting the battery was now completely drained.
    -Attempted to start the engine one last time and was no longer even getting the clicking sound. Central locking / windows / anything that uses power now dead too.
    - Confirmed battery was flat by hooking it up directly to the girlfriend's car and trying to start it - no sign of life.
    - Hooked girlfriend's car battery up to the Vec and tried to start it, no sign of life either (not even the clicking sounds)
    Can anyone suggest what the problem might be? Is my alternator goosed? (but then why doesn't the working battery even make it click?). Anything else I should try to do or that I might have missed in order to find the guilty party?
    Thanks in advance
    Hutch
    Oct 2011
    Essex
    What size battery has the other car? You might need a bigger one on a longer jump if its dead flat.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    You will need a heavy duty battery to start a V6 cdti bud
    Paris
    Trim : SRI
    Engine : Y30DT
    Hahaha I checked the voltages but didn't even think to check the rating - turns out it's a 20Ah no chance!
    I'm gonna need a bigger battery. I'll report back when I've found one.
    Cheers for the quick replies!
    Hutch
    Yes, the handbook also advises not to charge the battery from another vehicle (for this engine)
    The solution would be remove the battery and have it recharged
    A new a battery for this type is not cheap, a new OE battery comes in at around £150
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    Hhhhhmmmmm....... My first thought from reading GF's car was bigger battery is going to be required, I maybe wrong just got image of a clio with an engine barely bigger than the battery in these things.
    Paris
    Trim : SRI
    Engine : Y30DT
    Yep, battery size seems to be the (really) obvious thing I didn't take into account... it's a 1.0 Micra from 1999
    Apr 2011
    EMEC #3
    Quote Originally Posted by hutch85 View Post
    Hahaha! Even worse than I thought lol!
    That engine/battery stood no chance.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Just bought a new Bosch battery for my V6 http://www.eurocarparts.com/ecp/c/Va...c1bc3d0&000020
    £73.39 inc VAT using "Winter15" code. VX stealer quoted me unhappy at £98.
    yes, after market batteries are cheaper, however an OE one is well expensive and is covered by a 5 year warranty
  1. Now for something totally different...
    By P3tchy in forum Styling
    Last Post: 26th March 2010, 14:28
  2. A dead 3.0 V6 CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 6th October 2009, 15:32
  3. totally new
    By stew299 in forum Introduce yourself.
    Last Post: 19th July 2009, 22:11
  4. CDTI SRI Dead Headlights (both of em??)
    By Warrenmole in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2009, 10:11
  5. Occasional Dead V6 CDTi
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2006, 17:46
