Results 1 to 8 of 8
Thread: How do i get to the back of 12v socket
    Oct 2006
    Suffolk
    Default How do i get to the back of 12v socket
    OK i need to get to the back of the 12v power socket the one at the front of the car ( ciggy lighter )
    How do i get to it, tried to remove ashtray base but couldnt do it ?
    Any tips, this is so i can power my Road Angel
    Note this is a Signum 2006 model
    http://forum.vectra-c.com/showthread...ter#post186831
    Wonderful thing that search feature!
    Regular Member sig63's Avatar
    Aug 2006
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Yep, but he possible has the same problem as I have: ashtray won't move
    Siggyman: shout if you manage to remove it
    Is that a difference on the facelift then? How do you get to the ODB II (Tech 2) socket then?
    Oct 2006
    Suffolk
    Quote Originally Posted by sig63 View Post
    I tried this but didnt want to pull too hard and break it !
    Yes the Tech2 socket is visible when the ash tray bit is lifted out but the ashtray lid frame is held in firm somehow
    Regular Member DennisTheMenace's Avatar
    Feb 2006
    Dorset
    It will unclip , take the inner section of the ash tray out so you can grip it and pull stright up , make sure you have removed the gear surround as well.
    Aug 2006
    member of the smoke patrol 230bhp+
    Quote Originally Posted by DennisTheMenace View Post
    TO THIS TIME IN NEEDING IT OUT I BOTTELED IT AT SAID TO MYSELF IM GOING TO BRAKE THIS IF I PULL IT ANY HARDER
    SO IT STAYED IN
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Engine : Z19DTH
    Year : Nosey
    If you don't have a rear lighter socket then you may have the wiring for it still. Mine has the live wires inside the centre box and that would be a much better place to take a feed from.
    Mine doesn't have the arm rest so it's quite easy to remove, just three screws but I've never attacked an arm rest one.
  1. socket set
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2012, 01:45
  2. USB socket
    By rockonoli1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 13:33
  3. Power Socket in back of vectra CDTI 2006 facelift
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 12:55
  4. 12v aux socket
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 20:58
  5. USB Socket/Aux In
    By armstma1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2007, 21:18
