Thread: 2.2 Pump and Reg.....
    Portsmouth
    Default 2.2 Pump and Reg.....
    Has anyone had problems with this since the recall in 2010?
    It seems mine has gone again, only ever had the regulator changed but now as out of warranty etc. I need both doing!
    If people have had it go, have they managed to get Vauxhall to give any assistance for the repairs? I know they did it a while ago but I think that was before the recall.
    Blantyre
    How do you know both have gone ?
    When my pump went it gave codes pointing to the regulator, however upon further investigation it was indeed the pump, regulator was fine
    I have a 3rd party warranty on mine ,
    11 Post(s)
    Quote Originally Posted by shankton View Post
    Mine was changed under warranty, along with the pump as they couldn't gurantee which component was at fault because of the misleading fault code it was giving.
    A year later, the regulator was changed again, as the 1st one they fitted was on the Vauxhall reworks list.
    The regulator they fitted to yours isn't like mine was it? ie, subject to needing a free replacement because the original one fitted was also faulty.
    Portsmouth
    My regulator has been changed twice once under warranty and the other on recall. Guess I should have been more demanding when they did the work under warranty and made sure I got a new pump also. Just assumed as the problem went away it was fixed. Guess it was and now the pump is screwed.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep had reg done no pump was all fine then pump went great
  1. away to pump 500L of heating oil with a 3.99 ebay drill pump.
    By TimTay in forum The 'Off Topic' room
    Last Post: 19th September 2011, 22:09
  2. HELP!!! oil pump
    By Awkward kid in forum Engine & Drivetrain
    Last Post: 30th January 2011, 20:05
  3. AIR CON pump
    By alijlacy in forum Engine & Drivetrain
    Last Post: 9th January 2011, 21:33
  4. which pump?
    By keith1983 in forum General Chat
    Last Post: 25th April 2009, 20:35
