Results 1 to 10 of 16
Thread: help with fitting towbar electrics
    Jan 2012
    swinton
    Default help with fitting towbar electrics
    as above please i have fitted the towbar with the bypass relay then i am stuck where to put the other wires to can i just wire them into rear lights any1 help please
    Regular Member Craig1985's Avatar
    harwich essex
    Yes, that's what I done. I used scotch locks and worked fine. Just use a circuit test totest each pin to see what they are used for
    Jan 2012
    swinton
    I have wired it up everything works untill u plug light board in i know the ligbt board works cos i tryed it on brother car can any1 help
    Dec 2011
    Seaham
    Make sure you have a good earth! Most faults with towing electrics are due to a bad earth.
    Jan 2012
    swinton
    Yeah got a gd earth when u plug light board in its making everything live d
    could it be the relay box wats fck and i need to use it my head burnt out with ideas
    Jan 2012
    swinton
    Aug 2010
    Leeds
    Scotch locks and tapping into a can bus system does not seem a good idea.
    Does this have the fuse box in the boot and a auxilary for the wiring harness which plugs in? I know my 06 astra did and this was the way i fitted that.
    Sigtuna Sweden
    Jan 2012
    swinton
    yes my fuse box in boot but know wiring for towbar can u think off anything else
    Dec 2011
    Seaham
    Has the Scotch locks actually made a good contact through the cable? Its better to scrape back the insulation and solder on directly.
    Test each connection with either a Voltage meter or a test bulb. If you still arent getting a signal through to the back, then it may be your towing relay box.
    Is the relay box earthed and also got a power supply to it?
  1. oem towbar electrics help
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2012, 23:14
  2. help with fitting towbar electrics
    By windy111106 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2012, 01:21
  3. Towbar electrics
    By jofenan in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 16:21
  4. Towbar Electrics
    By slipperysam1984 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2010, 15:53
