Thread: 4 wheel alignment. what are toe bolts?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question 4 wheel alignment. what are toe bolts?
    hi guys. went to get alignment today. the guy said my rear toe bolts have seized hard core and i will be needing new ones. i cant seem to find them anywhere, even on ebay. i dont really know what hes on about. could someone please point me in the right direction please?
    PaZ!
    Nottinghamshire
    Mine had seized in the bushes too - and sheared off when they were removed. New nuts and bolts are probably a dealer only part and they don't cost much. The ones that adjust rear toe are ones at the inner ends of the auxilliary control arms (the short arms that go diagonally forward from the wheel hub).
    The similar nuts and bolts at the inside ends of the lower control arms (the larger arms that run straight towards each other that you can see wheen you look under the back of the car) are used to adjust the camber. They'd seized on mine too so I had them replaced as well.
    Nottinghamshire
    If you wanted to replace all 4 sets of nuts and bolts for adjusting the angle of both of the rear wheels, here's what you'd need. Adjust the quantities to suit what you want to change:
    2 x 24422972 - 100mm offset bolts for lower control arm / camber adjustment bolt.
    2 x 24422973 - 85mm offset bolts for auxilliary control arm / toe adjustment bolts.
    4 x 11094488 - nuts, the same for both arms, one required for each of the above bolts.
    4 x 24428132 - offset washers, one for each nut. Not vital but I got some to be safe.
    Check the parts with your dealer to confirm that these are the right ones.
    These were the parts for my car which is a hatch - saloons, estates, and the Signum may be different.
    What you could do is go back and ask him to point out the parts and mark them
    Take the car to a dealership and ask them for the part numbers, they are marked for identification
    Buy the parts, then go back to the alignment outlet and ask them to refit during the alignment
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Thumbs up
    Quote Originally Posted by James24 View Post
    Cheers mate. Just bought the parts you mentioned. Should do the trick nicely.
  1. wheel alignment
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 10:57
  2. Wheel alignment
    By crazy-dee in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2010, 18:47
  3. Wheel alignment
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2009, 21:11
  4. 4 wheel alignment
    By parsco in forum Handling & Braking
    Last Post: 1st April 2009, 22:45
  5. Spare Wheel Bolts From Locking Wheel Bolts
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2007, 16:55
vectra c rear wheel alignment bolt
vectra c rear camber bolts snapped during wheel alignment
vectra c rear wheel toe
toe bolts vauxall vectra
vectra rear alignment bolts
vectra c rear toe bolts seized
vectra rear toe issue
vectra camber adjustment
vectra camber bolts and toe bolts
wheel alignment arm bolts
vectra c rear wheel alignment bolts
allingment bolts vectra c uk
signum tow adjustment bolts
vectra c rear toe
can you adjust camber on vectra c 1.8
adjusting toe on a vectra c
