Thanks Thanks:  1
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: CDTI Swirl Valve
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Default CDTI Swirl Valve
    All,
    Just priced the said part today at the dealers. Thought it maybe of interested to members who's CDTI'S are coming out of warranty. My dealer has done loads of these and even carries stock of 5 so that in my mind proves it is becoming a common fault.
    The part comes in at around £130 retail but if you can get decent discount it comes at about £95 plus VAT.
    Paul.
    Regular Member ion's Avatar
    walsall
    I just had mine done under warranty.
    The car drove cr@p while it was faulty, it got worse over a period of time.
    What does it do?
    Leicester
    It is the valve that controls the fuel flow into/out of the swirl pot in the fuel tank. My first 1.9 CDTi150 (04 reg) suffered this, but my new one seems OK.
    Dec 2005
    St Helens
    Whats the syptoms
    Leicester
    The car can sonetimes hesitate then come back to life again.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    swirl actuator is situated in the inlet manifold i have change loads of these we usally change the inlet manifold and the swirl actuator control motor .. the swirl actuator helps with cold start up and is used some times in the engine run program .......usally the inlet manifold buter flys get cloged with **** and this knocks the motor out of sink the later manifolds are modifyd to stop the build up of crud ............
    walsall
    Quote Originally Posted by benny View Post
    Hope mine doesn't fail again, the car had no power above about 2500rpm. It was seriously rubbish to drive, but deteriorated over a period, so for ages I didn't notice & just thought it was a characteristic.
    Then I noticed I was really flooring it to accelerate & started to realise that it wasn't like that to begin with.
    Whn fixed TOTALLY different & still feels great now.
    It does concern the manifold as I read the engineers report.
  9. Thanks stevecon thanked for this post
  10. #9
    Regular Member fireblade's Avatar
    Feb 2006
    at home
    I had my swirl valve changed under warrenty
    The car just went into limp mode while driving at 30mph stopped engine and it seemed ok a few minutes later it went into limp mode again this continued for the journey got to the dealer who said it is a common fault with the cdti 1.9 engines they changed the swirl valve and it has been ok ever since
  11. #10
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It's the old Exhaust Gas Recirculation that puts all that **** into the system. It might be good for the environment but it doesn't help the car in terms of power or life.
  1. 1.9 CDTi Swirl Valve Issue
    By Ninj in forum Engine & Drivetrain
    Last Post: 12th November 2012, 20:33
  2. 1.9 CDTi 120. EGR, Swirl Valve or ???
    By mjsignum in forum Engine & Drivetrain
    Last Post: 13th April 2010, 15:23
  3. CDTi 150 Swirl valve thing !?!?
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 21:05
  4. 1.9 CDTi Swirl valve
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 16:14
  5. CDTI Swirl Valve revisited
    By chrish in forum Engine & Drivetrain
    Last Post: 26th August 2007, 11:44
