Thread: 2.2 DTI vacuum hoses / pipe
    Default 2.2 DTI vacuum hoses / pipe
    Hi, i need to replace the vacuum hoses / pipe on my vectra but can't find any?
    I think they are called vacumm hoses it goes between the solenoids and actuators for turbo etc. They have 3.9mm OD and 2.5mm ID can anyone point me to the correct name and a link to ebay or some where please.
    Alistair.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    I used this sort of stuff. 3 M should be more than enough http://www.ebay.co.uk/itm/2mm-BLUE-S...item2a1404d741
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I got some for my DTi, think you use 3mm internal diameter Just search silicone hose on ebay and have a scout on there, also check out innes signature as he has a link to when he did his.
    Sent from my iPhone using Tapatalk
    Oct 2010
    Walkden, Manchester
    I know its intercooler hose thread but it goes into vaccum pipes to. here ---> http://www.vectra-c.com/forum/showthread.php?t=116528
    Thanks, my hoses look different like a smaller hoses pushed into rubber elbows, is this standard? guess i can remove rubber elbow and fit silicone hose.
    Attachment 50473
    Trim : Sport
    Engine : Petrol
    Yeah mine were the same, just remove one pipe at a time, cut to length and replace with the silicone pipe. You get a good snug seal and no elbows are needed. It just pushes straight on with the 2mm ID pipe. The stuff in my link
    Smile
    Thanks a lot ill get some ordered.
    exeter
    so what size is it ? some are saying 3mm and others say 2mm . because i have just ordered 3mm to fit
    Regular Member Thom's Avatar
    Nov 2010
    UK
    i have just done my 2.0dti with 2mm ID silicon hose, apparantly 3metres is all that is needed but seeg as the seller sent me loads more i dont know how much i used.
    exeter
    i got a 20 dti and have just ordered 3mm . i hope it fits
  1. vacuum pipe size
    By jonny22 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2012, 13:26
  2. vacuum pipe
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2011, 16:27
  3. upgrading vacuum & turbo hoses
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2010, 16:44
  4. 2.2DTi Y22DTR vacuum hoses scheme
    By Zemi in forum Engine & Drivetrain
    Last Post: 5th October 2010, 15:45
  5. vacuum pipe?
    By tj56 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2010, 09:34
https:www.vectra-c.comforumshowthread.php153735-2-2-DTI-vacuum-hoses-pipe
2.2dti 92kw vacuum hose
vectra c 2.2 dti vacuum pipes
size of vacuum pipes vauxhall vectra c 2 mm or 4 mm
vauxhall vacuum hose
vacuum pipes for vectra 2.2 diesel
pipe in vectra
vauxhall zafira vacuum pipes
vectra c vacuum pipes
zafira dti vacuum pipes
vectra c hose diagram
vacuum pipe vectra c dti
vauxhall 2.2 dti vacuum hoses
signum 2.2 dti vacuum diagram
vectra c dti silicone vacuum hoses
vacuum hose vectra c
vacuum lines 2.2dti
vectra c vacuum hose
opel vectra 2.2 dti vacuum
2.2 dti vacuum pipe
vauxhall vectra c dti vacuum pipe size
2002 vectra 2.2 cdx dti vacuum pipes layout
vectra c vac pipe
hose vacuum vectra c
vacuum hoses for opel dti
