Thread: Stuck lambda sensor!
    Chelmsford
    Default Stuck lambda sensor!
    The damn thing is stuck in the old exhaust front section!
    Anyone got any tips on how to get it out in one piece?
    Jun 2011
    brum
    vaseline?
    Blow torch.. heat it up then try, alternatively soak it with wd40 but that needs doing over the course of a week, sometimes two, to be of any effect. If none of that works you could try one of the sensor sockets if you havent already, they have the inside shaped so as not too break it and might let you get some more torque on it ?
    Chelmsford
    i'll give the blow torch a go mate, thanks!
    Oct 2010
    Somerset
    Vehicle : Vectra C 1.9
    Trim : SRI
    Engine : Z19DT
    Mileage : 147000
    I had a similar issue on a vectra B I used a combination of a blow torch and one of these
    http://www.google.co.uk/products/cat...ed=0CEIQ8gIwAQ
    Although it was slightly bigger than the one above as the tighter you try to turn it the harder it grips, was a bit of a nightmare but it did eventually shift
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    your going for it tonight aint ya? Take it you need the car for the morning lol?
    Chelmsford
    I've been a lucky boy! Gave it a blast with my plumbers lamp and out it came.
    Now nicely fitted in the new pipe, all working properly.
    Managed to solve my rattling issue too. Found the heat shield above the first silencer was hanging off! The area around the mountings had all corroded (only off-side for some reason, the nearside were all fine!) Few big washers and it's held tight again.
  1. Y can't I get my lambda sensor out
    By danno91 in forum Engine & Drivetrain
    Last Post: 31st August 2011, 18:13
  2. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  3. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
