Results 1 to 10 of 13
Thread: squealing brakes
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    Default squealing brakes
    had new discs and pads fitted back in august and a couple of days ago the front o s started squealing after inspection there is 2 rings in the centre but not heavily scored what could it be help
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Could be pieces of grit lodged between pads and discs, It looks like you will have to strip them down and clean them. Don't be surprised if you don't see anything as it only needs a small piece of grit to cause the problem. Either that or the garage never changed the pads.
    3.2 v6 Signum and loving it
    Jul 2011
    burnley
    they were all new as i purchased them my self .
    will i need to replace the discs !!!!
    Jul 2011
    burnley
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    78 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Just a thought did u copper grease the back of the pads?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by dcm23251981 View Post
    Hard to say without seeing them. If it is only a liight groove and they were new ones I would probably clean and re-use but as I say difficult to give an answer without seeing them.
    Jul 2011
    burnley
    yeh every thing where all done and sound as a pound done about 5k since having them changed passed mot with flying colours and then since the other day the problem started
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Lack of copper grease on the sliders and missing spring can cause squealing , but there is a groove on the disc, which makes me think it could be grit lodged between the pad and disc.
    Jul 2011
    burnley
    if weather permitting i will strip it down and take pics just to add to note the squeal gets louder when turning the wheels!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    The other thing it could be is there is a small dust gaurd between the hub and disc, which, if you look at it from the back of the wheel, sits at the bottom of the hub. Sometimes this can start rubbing on the disc and causing a squealing/ rubbing sound. The remedy for this is usually bend it gently away from the disc using a long screwdriver or lever. this should be enough to dislodge any grit stuck in there. I would try this first before you do anything else, as it is a fairly common problem.
  1. Squealing Brakes
    By richardg3.2 in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2012, 16:17
  2. Brakes squealing
    By davidlewis24 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 20:33
  3. Squealing brakes
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 21:27
  4. squealing brakes
    By HooDLuM_X in forum Handling & Braking
    Last Post: 17th July 2008, 11:24
  5. Squealing brakes
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2008, 19:19
