Thread: Need some help
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Need some help
    Hi guys I'm going to get my bilstein b12 kit end of the month and I also want to get some power flex bushes what do they do is it just arb bushes I will also replace drop links too
    Regular Member Keif's Avatar
    In the Garage
    Powerflew now do most bushes for a Vectra C/Signum, so IMO front and Rear ARB bushes are a must, may as well get your front wishbone bushes changed at the same time. You'll need to get you suspension alignment checked after you fit your new suspension anyway, so may as well get as much done (if funds allow) in one go.
    As for the Drop Links, fit some Mayher (sp?) Saab uprated ones, alot sturdier than Vauxhall ones.
    With the rear suspension again you have a wide choice. I think the only bush PowerFlex dont do is the lower arm bushes, the upper control arms are now catered for at last.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by Keif View Post
    Where is best to get this kit is it power flex site itself
    In the Garage
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    So if i did front and rear ARB bushes, uprated drop links and also front/rear wishbone bushes with new suspension this should do the trick
