Results 1 to 10 of 15
Thread: 150 injector problem
    Sep 2011
    middlesbrough
    Default 150 injector problem
    ive bust the poppet valve stem wen removing injectors with the laser removal tool, my local so called diesel specialist wouldnt sell me them, cant find out on ebay, does anyone have any ideas where could purchase them????
    thanks lee
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Vauxhall?
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Dealers
    Sep 2011
    middlesbrough
    tried dealers, they just tried selling new injectors not very helpful,
    Regular Member benny's Avatar
    Feb 2006
    dudley
    erm how have ya been messing with the poppet valves when removeing the injector ? you broken the rocker cover to ? ......or are you talking about something else and got the name wrong ? .............you got a pic
    Sep 2011
    middlesbrough
    not to sure about the name, i had to remove top off injector to screw the 2 sockets to pull injector out, to screw the internal socket on i had to remove a 'c' clip a fan shape part, spring, then use a laser tool to undo a hexagon shape nut but tool not long enough and snapped the stem wen undoing the nut, i can put pic on tomorow if anyone can help.. thanks lee
    Sep 2011
    middlesbrough
    the reason for takin injectors out, i had 5 broken camshaft followers due to inlet manifold change and water got into num 1 n 3 pots causing to hydraulic and snap followers, camshaft housing fine all back together , just need to fix injectors now
    Nov 2011
    Is it pictured in this here?
    http://eper.fiatforum.com/eper/navi?...D=92&DRW_NUM=2
    If it's part of the injector assembly, then you may have to fork out for a new one. Used the above link to see if that's what you need since fiat and alfa use the same engine
    Sep 2011
    middlesbrough
    thanks for quick reply, its actualy inside the injector itself, thought you mite be able to buy a repair kit , ill post a pic tomorow, thanks
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    If the injector is damaged in the way you describe, I have to ask is there any tar like stuff round the injector? If so the seal may have been leaking allowing oil and crap to mix. This can cause the injector to sit very tight and only real way of removing it is to take the head off again.
    Insignia VX-Line Nav CDTI 170.
  1. Injector Problem
    By vectra19 in forum General Motoring Chat
    Last Post: 8th June 2012, 23:40
  2. Injector problem
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 29th July 2009, 13:58
  3. 3rd injector problem
    By smurfy in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:56
  4. 20 dti injector pump problem
    By stevie b in forum Engine & Drivetrain
    Last Post: 20th March 2009, 20:55
  5. EGR or INJECTOR PROBLEM
    By dingle in forum Engine & Drivetrain
    Last Post: 18th May 2008, 16:56
