Thread: HELP, noise at 1500 rpm
    Dec 2010
    wirral
    Default HELP, noise at 1500 rpm
    ive a 120bhp 1.9cdti singum on a 56 plate, 45,000m miles with an 6 speed manual box,
    ive noticed when i drive and go through the revs, at 1500 rpm her is a hum, when i leave the revs there it stays, but i can drive to 1600 and it goes!, its in gears 2, 3, 4, 5, and 6?
    any ideas?
    should i be worried its gonna die? its driving ok?
    HELP
    merseyside
    I've got a problem like that,gonna watch this thread to see if anyone know's what it .is
    Sep 2011
    Norway
    I have the exactly same problem with my norwegian Opel Vectra 1.9CDTi 120. I bought the car few months ago and my Opel-dealer have searched for the cause of this several times without luck... Myself,i am wondering about the flywheel..but they won`t change this because there is no sound... I love my car,but this **** is making me hate it...
    Sep 2011
    Norway
    hmm.. I see you talk about sound..i was thinking you meant "shaking".. that`s my problem..around 1400-1500rpm in 3,4,5 and 6.gear.
    Dec 2010
    wirral
    this is just a gentle hum noise! weird and annoying.
    merseyside
    I had the flywheel amd clutch changed about 8000 miles ago (that was ratteling),mines been makeing that noise well before.and it still is.Its like a hum at about 15000 revs,doesnt do it all the time,but more noticeable,in 2nd gear,and goes when the revs drop under 15000
    Dec 2010
    wirral
    im now thinking maybe erg opening?
    Default Me too
    I have this as an engine judder at 1500-1600 revs accelerating lightly. If you accelerate harder you pass the 1500-1600 revs spot too fast to notice. So you notice it in 5th or 6th as the acceleration is slower. The last few posts indicate that the EGR valve opens around that mark - is that right?
    Jun 2011
    South Yorkshire
    Default Noise at 1500rpm
    Not sure if this helps but I work away in three month periods so my my Vectra SR1 cdti150 estate stands on the drive and only started once every couple of weeks to keep things moving. Last time I went home the car was started and I heard this strange humming noise at around the same rpm. It was obvious and noticed as soon as I drove off the drive. I switched off the AC and the noise went away. Next day I noticed that the Air con was not really cool as it had been previoiuusly so I got it regassed and the humming noise vanished.
    Might not be useful but I thought I would share my experience.
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    You sure it's just not resonance at that rev range? There's a multitude of things that could cause humming across the rev range. How noticeable is it? Would a passenger notice it without warning or does it seem worse because you're looking for it now you've noticed it?
  1. 1.9 CDTI 8v 1500 rpm MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 26th August 2012, 10:34
  2. quoted £1500 for this repair.
    By ryantcb in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2011, 15:09
  3. £1500 bill for CDTI
    By ONEMINUTESILENCE in forum Engine & Drivetrain
    Last Post: 24th July 2011, 12:04
  4. 3.0 V6 hesitation 1500 rpm (solved)
    By yoladeuche in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 10:59
  5. Juddering @ 1500 rpm
    By big nath in forum Engine & Drivetrain
    Last Post: 13th January 2010, 23:32
