Thread: garage door
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default garage door
    i have an up and over style door on my garage but the lock was broken even before i moved in.
    i am looking to make the garage more secure as it is slowly filling up with quite valuable car parts now.
    anyone know of any security products other than the garage defender type locks?
    i had one of those and the key snapped in it meaning we had to force it out of the ground meaning thats not the best option!
    the garage is cast concrete sections so the best products would bolt into that rather than the floor.
    thanks guys
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    couple of pad locks with an alarm inside, and put a sign on door saying alarmed.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Dont try drilling the thick edge parts of the concrete garage panels.
    They have steel reinforcement and pieces will chip off.
    If you do want to drill into them, do so on the thin sections in the middle of the panels.
    Also if you add too much extra weight to the door, it will be difficult to lift, and may even come down by itself.
    The choice will largely depend on if you lock the door from the outside or the inside.
    Sep 2011
    Birmingham
    Trim : sri
    i can access the door from both sides if thats what you mean so the locks can go on either side tbh
    May 2011
    Eastbourne
    Shotgun Alarms are quite cheap, the fire a blank 12 bore cartridge. Seriously loud and a fair bit of smoke too. I dont think anyone would hang around long after that being activated.
    spoons
    Guest
    Quote Originally Posted by rottertron View Post
    Including the owner
    Feb 2007
    North west
    I put two bolts on the inside of the door going down into the concrete floor that i use when we are away. Electric opener locks it while home.
    May 2011
    Eastbourne
    Quote Originally Posted by spoons View Post
    Including the owner
    Funny you say that, ive set it off accidentally. For test purposes of course!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I've seen people put a hasp on the top or bottom of door, screwed to top frame or ground with the screws you can't undo and a security padlock on it.
    Sep 2011
    Birmingham
    Trim : sri
    bolting to the floor isnt ideal tbh as i am not sure how good the concrete base is.
    i guess i need to test the floor see if its up to holding anything.
    we managed to rip the garage defender out of the concrete hence my thinking its not brilliant.
    afaik its original and the house was built in 1935
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. OSR External Door Handle & OSF Door Lock
    Last Post: 29th May 2009, 17:14
  4. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
