Results 1 to 10 of 20
Thread: MOT advisory... Play in steering rack joints
    Chelmsford
    Default MOT advisory... Play in steering rack joints
    Hi guys,
    Just passed the MOT today... yaaay!
    However, got a couple of advisories
    - Play in steering rack inner joint
    - Both rear tyres showing uneven wear (close to limit)
    Questions...
    What is the steering rack inner joint? Easy/cheap job to replace? Is this the track rod ball-joint?
    Why have my rear tyres lasted less than 2 years (about 22k). I've never known a pair wear out so quickly before on the back.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Usually I'd have said that uneven wear in the rear tyres is going to be either rear shocks gone or rear upper control arms gone (or both) but if it's passed the MOT today then that's less likely.
    It's possible your camber settings are out but you'd need to get a Hunter re-alignment done to get that sorted and I'd replace the tyres before you have that done to be honest.
    The Vecs are well known for eating rear brake pads like there's no tomorrow, but not seen any major issues with rear tyres unless there's another issue.
    Quote Originally Posted by DNS View Post
    This is the nearside end between the rack and rod
    Usually the first sign of a rack on its way out
    Not cheap either, start saving up now
    2 years for rear tyres is excellent
    Presumably you've not been swapping rear to front as they have worn out
    As above, suspect the rear camber is incorrect
    Take the current rear tyres down to 3mm then replace them, full alignment check, then swap tyres as they wear
    Chelmsford
    Is the track rod part this:
    http://www.eurocarparts.com/ecp/c/Va...0450b84&000347
    I assume the wear is the cause of the knocking I've been having for a few months now (assumed it was drop links but replacing made no difference).
    I'll get the rear tyres done when they wear down a bit more and then get alignmycar.co.uk to check everything out. I wonder if the worn rubber is why I've been getting a repetetive drone from the rear wheels recently...
    Cheers guys.
    Chelmsford
    Deleted
    Last edited by DNS; 10th January 2012 at 18:36. Reason: the double post bug strikes again...
    Aug 2011
    Bristol
    inner tie rod end as below
    <a href="http://www.vauxhallworldparts.com">Vauxhall Parts</a></font><span class="style101"> | </span><font color="#FFFF00"><a href="http://www.vauxhallworldparts.com/va...7434">Vauxhall Part Number: 93187434</a><br>
    I have the same advisory and found out it has been on the previous MOT's for 4 years and never been done.
    Waiting to fit them at the moment. It took me ages to find out the term
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Inner tie rods. Are £35 for pair from Vauxhall on trade.
    Would also recommended changing the outer track rod at the same time.
    And easy enough to change yeah.
    Can post you a how to if needed or your looking at about 2 hours labour from a garage
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    This shows how much play I had in my tie rods
    http://i287.photobucket.com/albums/l...l/948f505f.mp4
    Aug 2011
    Bristol
    can I have the how 2 as I only saw a video from an american car?
    Bad for telling me to change the outer as well as I did not purchase this and was not aware it should be changed at the same time
    Chelmsford
    Cheers guys. Parts I was expecting.
    I'm planning on doing the work myself when I get time, will get the parts from motor factors tomorrow.
  1. mot advisory offside inner steering rack joint has slight play
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 12:29
  2. Play in steering rack? Vec C
    By Mopar Man in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2011, 19:19
  3. steering rack play, maybe?
    By iasha in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2011, 21:28
  4. Cost of inner rack joints and fitting?
    By lee gsi in forum Handling & Braking
    Last Post: 19th January 2011, 08:53
  5. Steering rack play
    By K18 JRT in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2009, 05:12
https:www.vectra-c.comforumshowthread.php153670-MOT-advisory-Play-in-steering-rack-joints
vectra c steering rack inner joint
inner joint of a steering rack renault scenic
steering rack inner joint corsa d
play in steering rack inner joint corsa
is it easy to replace steering rack on vectra
vauxhall corsa mk2 steering rack inener joints
signum steering rack inner joint
play in steering rack inner joint renault scenic
how much to fix ns steering rack inner knuckle
nearside front play in steering rack inner joint vectra
