Results 1 to 9 of 9
Thread: gears hard to get.
    Apr 2009
    leeds
    Default gears hard to get.
    hi just bought a 1.8 vectra c 52 plate for the other half. all was fine for a few days then today. the gear stick went stiff and would not select gears. so stopped pumped the clutch and the gears came back. drove fine rest of the day. then did it agian. pumped it and fine. but when it does it im not looseing any pedal pressure. bleed the system tonight gonna see what happens. but if the slave cyclinder had gone they would be no pressure.
    any ideas when its working fine its great.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I would say the slave cylinder
    Sep 2007
    scotland
    I would say worn clutch as you need to pump it therefore pushing the slave further out to engage the plates .
    Jun 2011
    Herts
    it is about 650 quid........
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Had a similar thing happen to my son's corsa the other week. He lost the clutch and could not select gears. and then the clutch started working again but clutch feel was not the same. On strip down a section of the clutch friction plate had separated off the plate I think initially it had jammed and then dropped clear. The slave cylinder was also on its last legs and needed replaced.
    So new clutch and poss slave cylinder. Probably worth replacing if the car has done hi miles anyway
    Apr 2009
    leeds
    can i get a slave cyclinder from a parts shop or does it have to be vauxhall. was thinking if i get the parts it might be cheaper just to pay someone to fit it
    Apr 2009
    leeds
    found today that when it sticks. if i lift the clutch pedal up a bit it comes back. but im not loosing pressure.
    Dec 2011
    Northumberland
    Did you sort the problem out? All parts are available aftermarket i believe.
    Sep 2011
    Glasgow
    i have this exact same problem although mines is only 1st gear and not very often did u find out what it was?
  1. Replies: 7
    Last Post: 2nd September 2012, 21:00
  2. getting gears
    By mitch in forum Engine & Drivetrain
    Last Post: 8th December 2010, 01:43
  3. Not enough gears!
    By Flaninacupboard in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 08:48
  4. 1st 3rd & 5th gears hard to engage
    By scott_vectra in forum Engine & Drivetrain
    Last Post: 14th November 2009, 13:26
  5. How many gears
    By Jason123 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 10:21
hard to get gears on vectra c
