Thread: Where do i start.... Battery, fuel. Omg!!
    Jun 2009
    belfast
    Exclamation Where do i start.... Battery, fuel. Omg!!
    For a while now my 05 CDTI (120) has been hard to start when it cools down, it would whine and splutter as if it was drawing air in somewhere before firing to life but it has come now where the battery is draining before it kicks so I've been jump starting it with my wife's car. i have checked the hoses and pipes for breaks and all looks dead on but I did notice a damp patch on top of the diesel filter housing so i replaced the filter hoping i had found my problem. the next morning i turned the key , she whined and spluttered for about 20 seconds before the battery died ....... AHHHHH!!
    Put the jump leads back on, whined and spluttered for another 15-20 seconds and then fired to life. Not filter housing then! OK!. So I went to work (Taxi Driver) last night after jump starting about 8pm. Wasn't too busy so didn't really go too far but at 5am I got a run bout 20 miles up the motorway. When i got to my destination, I Realised that my wipers where slow and the radio turned turned off. the car was reving high and the abs lights came on the dash, power stearing then failed and the spanner on dash came on. all power from the battery had gone, managed to crawl the car home, knocked her off and now she is dead
    I AM BAFFELLED! has the battery sh!te itself or the altanator. How do i test it!?
    I would appreciate it if anyone can advise me on what to do next because i have run out of ideas and patients. could all the jump starting wreck the battery? why would it die all of a sudden with no warning? and when i get the power sorted why is she hard to start? thinking glow plugs next... is there a way to test these?
    please, please, please...... if anyone has any ideas, can u share them with me
    thanks in advance
    Marty
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Alternator is dead and more than likely kileed the batt now aswel.
    Need to check glow plugs that all are getting 12v andnthen check resistance to aswel.
    Cold starting issue on the 120s is an issue that a lot of people are having but can't find a definitive answer.
    Noise I would be checking alter belt etc, but this may gonnce a new alt is fitted.
    Is it the original batt? As if it is could be justna couple of cells have died andngot giving enough cranking power.
    So I say change batt and alt, use a genuine alt as vecs can be twitchy using after market ones
    Hth
    Adam
    Jun 2009
    belfast
    altanator was replaced bout year and half ago now. before it packed in last time my battery warning light came on about 2 hours before the battery died, this time there was no warning. would this make a difference. really hope its not the altanator because wasnt cheap last time. bout £350 i think
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah although no charge warning light appeared it still sounds like alt to me.
    Maybe jump start it, and get multimeter and check charge
    Jun 2009
    belfast
    np adam. thx for ur advice. gonna borrow a multimeter now, stick the battery on charge o
    vernite and check it in the morning. fingers crossed. do u no how to test the glow plugs with the multimeter? sorry for being a melt.
    Jun 2009
    belfast
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Turn the meter to volts black lead to earth red on the top of the glow plug should give you volts reading
    Then turn to ohms for resistance should ideally take the glow plugs out but can still be done in place it's just not as good
    Jun 2009
    belfast
    ok thanks mate
  1. Can the vectra start if the battery key is dead?
    By danlat1415 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th July 2012, 10:44
  2. Battery Has charge, Car won't start.
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2010, 10:20
  3. Car now won't start after disconnecting battery
    By onlymeagain in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 15:01
  4. new battery car wont start
    By mac15 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2009, 10:38
  5. Vectra C can't start after battery removal
    By tomek80 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2009, 19:22
