Thread: rads heating up but not coming into car
    Jan 2012
    essex
    Default rads heating up but not coming into car
    Just replaced both rads and fan, topped up on coolant, the coolant is circling round ok, but no heat is coming into car!
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Air lock in the heater matrix is my guess.
    Disconnect top hose going into bulk head. Turn heaters on full. And then pump bottom hose. Once Coolsnts comes out. Connect it back up.
    Top up expansion bottle and pump bottom rad hose. To ensure all air is out of system
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Switch on the ignition to position 2 with the blower and radio off. Turn the temperature control to see if the air mixture flap is actually moving. You will hear it if it is
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Can you hear the motor when you turn the temp dial?
    If you take the glove box out, to the right behind the stereo you'll see the blower / air distribution unit. You should then be able to see a red (i think) arm that moves the hot/cold flap. Move the temp dial to see if there is any movement
  1. Heating or not
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 20:12
  2. difference in rads?
    By crayon in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 21:10
  3. Over heating???
    By lukesignum in forum Engine & Drivetrain
    Last Post: 16th June 2010, 17:44
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
