Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi my vectra 2.0 dti on 53 plate on the turbo actuator rod is it spose to move on start up and when you rev it as mine does not move only by hand , is this right or is their a fault with sensor , any help thanks
    Regular Member Thom's Avatar
    Nov 2010
    UK
    mine was doing this and i had no boost. it turns out the bar itself had twisted somehow (i suspect the locking nut was on too tighly) and warped itself somewhat preventing smoth movement. try backing the nut off until its loose and then nip it down gently to eliminate this as a problem. it fixed mine.
    Jan 2010
    norfolk
    will try this tomorrow but is it suppose to move when you first start and also rev it because mine isnot what elsecould it be thanks
    Nov 2010
    UK
    it should have movement yeah, supposidly about a cm when you start it up, and theoretically it should move considerably when revving. but im no expert!
    Jan 2010
    norfolk
    Default vectra dti
    thanks thom , could it be the vacuum valve near back of airbox as this makes funny noise on mine
    Nov 2010
    UK
    i think i asked a similar question lately about a noise when turning the engine off, apparantly its normal if this is what you mean?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    check your vac system for leaks .....
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Noisy vacuum solenoids probably mean that it needs cleaning inside the vacuum solenoids.
    I dismantled mine and cleaned the rubber part that is the seal, but it's very easy to break the plastic clips holding it together.
    I did'nt try any spray cleaner, it might be worth a go, but i'm not sure about the rubber perishing, but trying an air line on the in an out vac pipe connections might be worth a go.
    Jan 2010
    norfolk
    ok thanks i will try any thing
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
