Thread: Disconnecting ECU and temp sensor on 3.2
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Default Disconnecting ECU and temp sensor on 3.2
    As mentioned on a couple of previous threads, I'm trying to work my way down the engine to replace the oil cooler and oil cooler pipes. I did get stuck on the intake flange which wouldn't let go, but now finally got that out.
    Next problem is disconnecting the ECU plugs as I need to unbolt the ECU to get to the cooler pipes. I've moved the locking levers forward but can't see how the plugs then pull out/off, and I don't want to force them and break something. Pic below - can anyone advise which direction and which bits come off please? In the pic the locking levers are fully forward to the unlock position:
    Also, there is a sensor take off on the coolant bridge as shown below (in box) - again I can't see how this disconnects, so same question really, as to which bit to press/unclip to get the connector off please?
    TIA
    South east
    No idea on how to unbolt it, but make sure the battery is disconnected before trying to remove the ECU - if the ECU still has power going to it when you remove it then you could fatally damage it.
    Feb 2007
    North Somerset
    Yep - disconnected the battery before starting taking things apart so no issues there.
    Feb 2007
    North Somerset
    Anyone, please? Before I take a lump hammer to the effing thing
  1. 1.8 ECU temp sensor
    By Wacky77 in forum Engine & Drivetrain
    Last Post: 24th December 2011, 22:37
  2. Outside Temp Sensor
    By vectra newbie in forum Vectra C / Signum Troubleshooting
    Last Post: 21st December 2011, 11:34
  3. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  4. outside temp sensor.
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2009, 17:03
  5. Temp Sensor
    By JSYSH466Y in forum Styling
    Last Post: 20th February 2009, 00:41
