Thread: It's my clutch guys :(
    Regular Member Admishere's Avatar
    Oct 2010
    Irvine, Scotland
    Exclamation It's my clutch guys :(
    Hey all, In the past two weeks I've been having a nightmare with my clutch/gears. Trying to put the car into gear is proving a mission at times, with all sorts of crunching and grinding coming from the gear box if it doesn't go in smoothly. Also getting slippage in 4th and 5th gear.
    Any ideas of what it is exactly/fixes?
    Really need an idea of what I'm looking at
    Its a 52 Vectra with 82k on the clock, no problems before
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like a knackered clutch mate!
    Especially the fact that it slips in the higher gears.
    ---Sent from my iPhone 4 using Tapatalk
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Could be worth checking gearbix fluid levels (can give notchy symptoms, but unlikely to make the clutch slip), or could be a contaminated friction plate (which would still require the clutch changing.
    But mostly likely need a clutch buddy.
    Oct 2010
    Irvine, Scotland
    Really? How much am I gonna end up out of pocket?
    Regular Member PORKBALLS29's Avatar
    Epping
    Depending if you need Dmf as well then anywhere from £350-£700I'm afraid.
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Depends on what engine you've got.
    Test it first though, when you're out and about, find a big hill, stick it in third or fourth at about 30-35 mph and plant ya foot.
    If it the revs rise but speed doesn't, more than likely it is your clutch.
    Not sure about petrol costs, but as far as i'm aware, changing the clutch at 82k on the diesels, you may as well do the dmf as well, and proces on here vary from £600 (private garage non oe parts) to £1200 (dealer prices).
    HTH
    Oct 2010
    Irvine, Scotland
    Got it fixed, they took £380 for it, inc labour
    Full Member
    Mar 2011
    n. ireland
    what all was wrong with it?
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Hi Guys
    By L666EAM in forum Introduce yourself.
    Last Post: 8th June 2012, 21:45
  3. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  5. will it fit guys?
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2008, 21:56
