Results 1 to 10 of 13
Thread: estate rear quarter glass
    Dec 2011
    liverpool
    Default estate rear quarter glass
    Hello, right today woke up to find that my car has been broken into and they had smashed the rear quarter glass to get into the boot and was just wondering how hard or easy it would be to replace as I'm picking 1 up on monday, is it bonded or just held in by the rubber? The car is a 2005 sri estate if that helps thanks in advance Ryan
    Mileage : 000
    I think they are bonded, but not too sure. I would see if your local "windscreen" man could do it for " a drink". He would know if it is bonded oe not. So might your local VX dealer.
    Dec 2011
    liverpool
    Thanks for that ed, also the car now says safeguard since the window has been smashed does anyone know how to get rid of this?
    Mileage : 000
    The safeguard is part of the alarm system. I would presume there are electrical conections on the glass that need to be pluged in somewhere when the new glass is fitted.
    Oct 2011
    Essex
    Your insurance normally covers all glass, not just the windscreen, give it a go.
    kent
    There are two small connectors under the bottom part of the trim for the alarm which complete the circuit I've got a problem with my alarm due to a break in the wire in the window and to disable that part of the alarm i removed a fuse from the rear fuse box, i cant remember which one but you should find it from a search( fuse 24 rings a bell).
    Ive got a replacement window waiting to go in which i picked up from car parts connextion, the window is held in with small bolts around the window which i believe are under the trim.
    Hope this helps
    sheffield
    Just held in with plastic 9mm nuts, no bonding....
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Dec 2011
    liverpool
    Thanks for the help everyone its much appreciated, I'm going to pick a window up after work tommorow and give it a go the bin bag an duck tape just hasn't got the right look
    Engine : 2.2 Direct
    You just need to remove all the trim on that side where the window is smashed.
  1. Fittin chrome window sills/rear quarter glass and a car smash!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 01:17
  2. vectra c quarter glass with chrome
    By deano1 in forum Parts for sale
    Last Post: 8th November 2008, 01:27
