Results 1 to 10 of 26
Thread: Rear int light wiring
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Default Rear int light wiring
    Hi the rear int light the ribbon/wiring is ripped does anyone know where the ribbon goes to and is it an easy fix also how much
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    goes to a connector in the front light.
    the headlining needs dropping to change it
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Have you change one m8 can I not just unplug from front light and pull through
    Nov 2009
    Warrington
    Quote Originally Posted by Critch View Post
    Ive repaired my rear interior light today as my ribbon cable was damaged and didint want the trouble of removing the headling so i ran 3 new wires though to the back and follwed the how2 thread for installing an interior light without a rear loom, i removed the front light and there was only one ribbon cable plugged in, i also thought the rear light plugged into the front light but i didnt see a plug for it tbh
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    ive not changed a vectra but my astra one was taped to head linning so i assume veccy is same.
    i think you could maybe unclip the old one and just feed the new one in but im not cetain on it.
    have you got the dmaged ribbon still, you could maybe repair it by soldering a piece of wire between the damaged parts
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by rob warrington View Post
    if its same as astra thn the ribbon is for rear light and the front lighht it fed via cables
    Nov 2009
    Warrington
    i tried to see where the cable ran to in my vectra but couldnt make it out. it defo didnt connect to the front light as i say there was only one big ribbon cable connected to my front light.
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Rob how old is your veccy mines a 57 plate and the light is standard fitment have you just link into front light. I will look at the how to thread
    Regards
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    not a clue then mate ive not had a look around that area in the vec, will maybe have a look one day after work next week
    Nov 2009
    Warrington
    Quote Originally Posted by Chewy72 View Post
    Regards
    58 reg mate, pm,d dude
  1. Rear light cluster wiring
    By Grumpy1954 in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 19:51
  2. Rear Courtesy light wiring
    By Street N in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2008, 02:00
