Thread: Abs warning light
    Regular Member Ben R's Avatar
    Jul 2011
    Southampton
    Red face Abs warning light
    My ABS warning light has started coming on intermittantly with no real pattern as to when and why. Is this some sort of brake pads low warning as well or am I about to have big problems?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Could just be a dirty connection on the plug on the wheel hubs or on the ABS pump under the bonnet.
    When it comes on, how long for?
    Does it go out from engine start, then come on and stay on?
    Brake pad warning will be the brake / handbrake warning light or the warning in the rev counter, so it's not that
    Jul 2011
    Southampton
    It seems to come on from engine start and stays on until I stop. The next journey it might not come on at all. Thats why I wondered if it was done sort of sensor problem or a loose connection somewhere. There are no other adverse affects although I haven't tried to activate the ABS while driving for obvious reasons.
    Jan 2012
    Ripon North Yorkshire
    Hi Ben, it is my first time on this Forum, so forgive me if i am not answering in the correct place, and it is 15 days later, i had the same problem with my Vectra 06 1.9cdti 120 bhp i was told by a mechanic that it was probably my front passenger side wheel hub needing replacing without even looking at it. i put it off for a while as it was intermittent. recently i changed my suspension front and rear, put it back to original height, and my abs light was on permanently i took it to an auto electrician and i was charged £50 for them to tell me that it was my front passenger wheel hub assembly needs replacing, apparently this is a common fault in the vectras.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Was it the hub, or was it the wiring that was actually at fault?
    There is a electrical connector on the suspension leg and it gets water in sometimes and cause electrical issues.
    If it was intermittent, then I cannot think of a failure mode in the speed ring that could be the cause.
    Maybe dislodging this connector caused it to come on all the time? Often times simply disconnecting it and reconnecting a few times will clean the corrosion and make electrical contact again. Maybe a spray of contact cleaner or WD40 too, and drying the connector internals.
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
