Results 1 to 9 of 9
Thread: 314mm brake pad removal spring
Hybrid View
    Jul 2009
    Brighton
    Default 314mm brake pad removal spring
    How do you get the retaining spring off??
    I've tried to prize it off, but it looks like its sprung loaded. As the callipers are painted, I've started to chip the paint off, so given up for now.
    Thanks in advance.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    They just lever out. They do ping out with some force tho.
    Jul 2009
    Brighton
    I tried that, but started prizing chunks of paint of the calipers. Does it have a spring clip in the middle?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Its weird their retained in the middle of pad.
    I just used a large flat blade screwdriver and they popped out
    Jul 2009
    Brighton
    Where do you prize it from?
    From the inner centre part out
    or
    The most outer part
    Does that sound like English??
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    If I remember I did it from the centre.
    Moderator paulhb's Avatar
    Dec 2007
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The centre of the spring is a small square with a lug towards the centre of the wheel hub, this lug slots into a small hole in a spring plate that is fixed to the back of the brake pad. Put the screwdriver betwen this spring plate and the plate on the brake and pry them apart just watch the spring clip it can fire out under great tension and do you some damage.
    Jul 2009
    Brighton
    Quote Originally Posted by paulhb View Post
    Cheers, I'll give it a go (wearing safety goggles!)
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    just place palm off the other hand lightly over it, whilst levering the screw driver with the other, stops things going wandering then aswel
  1. 314mm brake set up
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 11:51
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. 314mm brake set up £150
    By danBoy in forum Parts for sale
    Last Post: 16th October 2008, 00:55
