Results 1 to 10 of 14
Thread: 1.8l 16V
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Default 1.8l 16V
    Hi
    Im pretty new to the forum & have never posted before, although i have used some of your know how to change my blower resistor, pollen & air filter recently, nothing technical I know, but still pretty chuffed with myself as I havent been under the bonnet of a car for, well, too many years, anyway back to my latest problem....
    My battery just seems to keep going flat for no reason. Multimeter reads 12.6 volts from the battery and 14.9 volts when running so really dont understand why this is happening.
    I've been told the reading shouldnt be any higher than 14.4 volts when running, if this is right has my alternator over charged the battery and damaged it?
    Any help or advise you can give me would really be appreciated.
    Thanks in advance
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It sounds like something is draining your battery. Have you checked the boot light and glovebox light are not staying on when they are closed?
    Have you placed a multi-meter across the battery with the engine off and all doors closed, to check for current drain / useage?
    Your readings stated seem about right, so wouldn't worry there. I've never heard of a battery getting overcharged by a faulty alternator, but I'm sure someone will correct me on that!!
    For the boot light, remove the parcel shelf and close the boot. You should see the light go out
    For the glovebox light, remove the bulb and see if it still goes flat!
    HTH
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Havent checked either the boot light or the glove box, but I will, had to disconnet the glove box light when I did the resistor blower so it may be something I've done or not done when I reconnected it will check both of them, thanks.
    Doors closed and engine off battery reads 12.6v on the multi meter..is that what you meant? Sorry if I'm sounding a bit thick, like a said before, its been a long time.
    Thanks again for your advise
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Has your multi-meter got a setting to check to see if current is getting drained from the battery (as opposed to voltage in the battery)? That's what you need to check, with everything off and doors closed
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    It was a borrowed one so not really sure, but I'm borrowing it again on Monday so will have a proper look at it before I test the battery the again and follow your advise if I can.
    Ragarding the overcharging, I was told that if the alternator is over charging the battery it could have warped the plates and made them touch which would make the battery discharge itself. Dont know enough about batteries to know if this can happen.
    Really appreciate your help
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Battery will be ****ed mate just put a new one on my car
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    Did think about it, but need clarification on the alternator first cus I dont just want the same thing to happen to a new battery
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Well looking at the readings your alternator appears to be working fine, how long before your battery goes flat?
    As i will agree with Paul regarding the battery
    Vectra-C Enthusiast
    Dec 2011
    Leicester
    There doesnt seem to be a specific time scale. Has done it 4 times over the last couple of months. I can drive it home from work at night (25 minute journey), get up the next morning and its dead.
    Had to leave my car at work over night one day last week as the suspension spring snapped and destroyed my tyre, got to work the next day, put on the spare went to start it and nothing.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Thumbs up
    Quote Originally Posted by DonnaH View Post
    Donna, what Paul said, and from what you say above, just replace the battery
    Your readings seem fine from earlier, if it's just 4 times over the last couple of months, you're unlikely to have a current drain, as if you did, it would be flat every morning
    HTH
