Thread: help on what to change on rear suspension
    Regular Member bigbrox's Avatar
    rosyth fife
    Default help on what to change on rear suspension
    needing a little bit of advice,my mots due at end of month and need to change rear upper control arms am i better getting anything else changed at same time to avoid further labour costs and also is £70 a good price for the arms,thanks.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    £70 is a good price mate. Depends where you get them though. I got some from eBay for £30 for my last car. I've since sold the car but they had not given any bother. A lot of members say get genuine ones as they last longer
    Might be worth changing the rear springs and shock absorbers while you're at it, about an extra 20-50 minutes per side, unless they've been done recently.
    HTH
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by bigbrox View Post
    Not really buddy as the only thing that has to come out for removing the UCA is the rear spring so unless you want to fit lowereing springs then i'd just get the uca itself done.
    rosyth fife
    thats great guys thanks for the advice,dont need to change springs as in the summer changed them to eibachs as had another broken front spring.
  1. Rear suspension bush (lower) How do I change it?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 2nd December 2016, 12:41
  2. Suspension change
    By djr69uk in forum Handling & Braking
    Last Post: 17th August 2011, 00:10
  3. Advice needed - How to change vectra c rear suspension arms
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 12:06
  4. suspension change
    By tonyblade in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2009, 18:22
  5. Is it easy to change the Upper Rear Suspension Arm
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 26th August 2008, 16:19
