Results 1 to 2 of 2
Thread: Stripping a caliper??
    southampton
    Default Stripping a caliper??
    Right, my brake saga continues!
    I got the car through the mot, but now have a sticky caliper (my second hand one from a scrappy).
    My original caliper is in a lot better condition body wise, except the piston is in 3 pieces.
    My question- is it possible to remove the piston out of the scrappy caliper and put it in my original caliper?
    If so, how does one go about this?!
    Cheers guys.
    gwent
    It is possible but i don't think you can get rebulid kits as I build brakes for a living have you got a compressor with a air line so you can blow the piston out you might need new seal's as well.Once you got the piston by taking the bleed nipple out and using the air line to blow out the piston check for score marks if so don't use this piston if you can get a new piston lube the piston with brake fluid and the seals and gently push the piston back in the caliper by using a clamp once you got the piston back in use the air line to push it out but not all the way. Once you are happy with it just put it back on the car
  1. Stripping......
    By Whisky in forum Styling
    Last Post: 21st April 2011, 15:11
  2. Stripping
    By soulman in forum General Chat
    Last Post: 29th July 2009, 10:58
  3. Stripping is fun....
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 20:01
  4. stripping the head?
    By rickyroo in forum Engine & Drivetrain
    Last Post: 25th September 2007, 23:30
  5. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
