Results 1 to 10 of 13
Thread: Bought a 6 speed gearbox - will it fit?
    Regular Member Ant SRi's Avatar
    Merseyside
    Default Bought a 6 speed gearbox - will it fit?
    Need new gearbox for my 56 plate 2.2 direct SRi
    Assuming it was an F40 and that all F40's were the same, i got one from a 1.9 diesel.
    Garage just called to tell me it wont fit - should it or shouldn't it?
    Numbers off my old box is;
    FGP55192042 (also on diff; FGP55194293)
    Number from the diesel box is;
    F40, GM55350375
    Cheers, Ant.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    While they will both be F40's the bellhousing will be different and the gear ratios will all be wrong...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    m8, the gear ratios will be wide, you will find acceleration especially in higher gears quite poor.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    the starter on the 2.2 is on the front and the 1.9 is at the rear so the bellhousings are different
    sheffield
    If your car allready has a 6 speed, then it will be an m32 box, but be carefull as there are quite a few types of m32 box, but only one from a 2.2 direct will fit, dont get one from a 1.9 diesel, or astra, corsa vxr, another tip for you, look as much as you want but you wont find m32 stamped on your box......
    Merseyside
    Anyone want to buy a 38k mile 6 speed box from a 1.9 diesel.....!
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Isn't the 6-spd box in the 2.2 direct the F23 version?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes it should be F23.. thats the 5 speed one.. (also think the 6 speed is that.. but if you are converting from 5 to 6. you will also need new gear leaver)
    I know there is a webpage with all the different types.. but cant find it at the moment.
    Engine : 2.2 Direct
    Found it.. a 6 speed is a M32 a 5 speed is a F23
    http://www.opel-infos.de/getriebe/m32.html
    sheffield
    Is my post invisible.....post 5..
  1. 6 speed gearbox
    By billyyoung in forum Engine & Drivetrain
    Last Post: 16th September 2013, 07:54
  2. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  3. gearbox problems 6 speed
    By Даниил in forum Engine & Drivetrain
    Last Post: 8th October 2011, 20:43
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
fgp55192042
gearbox gp 55192042
z22yh 6 speed gearbox
does m32 6 speed fit corsa d 13 cdti
vauxhall gearbox fgp55192042
55192042 club opel
What is gp55192042
What is gp 55192042
corsa vxr gearbox
vectra 5 speed gearbox to 6 speed
55192042
