Thread: 6000k to 5000k HID change
    Engine : 1.9 CDTi
    Default 6000k to 5000k HID change
    Anyone gone from 6000k HIDs down to 5000k HIDs?
    One of my bulbs is very slightly flickering (Have to look really hard to see it) and I noticed the bulb had a white patch when I fitted it as it was an old kit (About 2 years old).
    So I am looking at replacing the bulbs.
    Rather than getting more 6000k ones I was thinking about 5000k ones so they are a bit brighter and whiter.
    Anypne done this?
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i had 6000k on my vec b and mr2 turbo i`m using 5000k in the vec and i prefare them as they are a brighter white light
    hth
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    sorry to blog in the tread but ive just fitted some 10000k and now im getting realy bad water condesce in the head light check the rubber cap and it looks all ok
    Engine : 1.9 CDTi
    Possibly trapped moisture when you fitted them.
    On a dry day take the covers off and drive with your lights on for a bit then put the covers back on.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I have 5000k's in mine, they look OEM white and they are bright. Been past PC Plod a few times with them on with no bother
    SHEFFIELD
    any ideas lee to fix this
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    5K's are the best colour ive found so far.
    @0114NIGEL0114 the moisture drips off the slam panel on to the rubber grommet on the bulb wires then leaks through the factory cover. I used some vasaline stop stop it getting in. Also the wires can bunch up and push the cover off the back of the headlight too, sticking the wires between the washer filler neck and the battery helps keep the pressure off the seal.
    scottish region
    4300k 6000k and 8000k I've had I prefer 8000 but have 4300 the now for brightness
    Jul 2011
    UK
    Year : 06
    I went from 6000k to 5000k best thing I did see Mich more with the 5000k much more white
  1. Fitted some 5000k HIDs today
    Last Post: 27th August 2012, 08:34
  2. 4300k or 5000k hid
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2011, 21:15
  3. HID Kit 6000k
    By RobW in forum Parts for sale
    Last Post: 2nd February 2011, 19:44
  4. HID kit H11 6000K 35W
    By MightyCris in forum Parts for sale
    Last Post: 20th December 2010, 15:18
  5. 4300k, 5000k or 6000k hids-direct kit?
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2009, 03:40
