Results 1 to 10 of 13
Thread: Cdti voltage ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Cdti voltage ?
    Can anyone tell me what their battery voltage is on tick-over for the cdti 150, It would be an advantage to know when the engine is NOT HOT OR COLD as such but just cooling down or warm, I'm having problems as some may know on tick-over & have found my injector deviation readings go out when the tick-over voltage is below 14v in the same situation, When started the throttle is not touched & allowed to tick-over as normal.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It should be between 14.2 to 14.4 mate
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Over 13.6 volts don't worry after running for 2-3 mins
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    My problem starts when, on start up its only just below 14 so i need an average of poeples to know what its supposed to be to pin point this exactly cos its driving me potty.
    north east
    if you put a jump lead from the engine to the body is it any better ? ( obviously dont drive round like this but good for diagnosis
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Dont know but i will try it today, cheers anything's worth a try!.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check battery leads for high resistance.
    Full Member Big Sig's Avatar
    Quote Originally Posted by the-wizard View Post
    So whats the problem? Is the battery going flat? Do you have lights on the dash? Just after start up it will be a bit lower than the 14ish volts due to the start up load, but within a few seconds it should be up to about 14.5v.
    How do you know what the voltage is on start up? have you fitted a volt meter?
    West
    is the motor starting & running ok?
    according to the cd70 test mode my motor sits around 14, sometimes lower due to the amount of power use IE. heated seats & rear screen etc...
    If you have no running or starting issues then don't try fix what may not be broken... if it's slow starting then have the battery checked.
    there is a reason they don't fit gauges for everything, there is a massive range of "normal" that would make people think something is wrong.
  1. What voltage should the alternator be producing (3.0 V6 CDTi)?
    By ph67 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:37
  2. Vectra 1.9 CDTi 150 Alternator / battery voltage
    By trucklord in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 10:06
  3. What can cause a voltage drain...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2010, 19:17
  4. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
  5. Alternator Voltage
    By Godzilla in forum Engine & Drivetrain
    Last Post: 10th June 2010, 21:47
vectra c voltage injector
