Thread: Intake Air Flap Actuator
    Jul 2011
    catterick
    Default Intake Air Flap Actuator
    Hi All,
    First timer to the site here, all help more than welcome.
    I have had huge problems with the engine management light on my 1.9 cdti 150, ongoing for months now, really annoying me and my bank account
    Great stuff on here to which i have tried to no prevail. I have cleaned through the throttle body & EGR with the help of the awesome how too. I thought I had nailed it.......
    But finally it came on and stayed on yesterday (P1125), on close inspection I could here air coming from the Air Flap Actuator, when i put pressure on it. Is that normal? Is this going to be another costly fix?
    Kingston Upon Hull
    Can i suggest you put this in the troubleshooting section you may get more answers
    Sorry i don't know the answer to your Question
    Jacko
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Kingston Upon Hull
    http://www.vectra-c.com/forum/showth...45#post1338145
    Yes i should have thought about that i have problems too with this in fact i hope to look at it this weekend
    Jacko
    Jul 2011
    catterick
    confused
    I will fire this into the troubleshooting section, first timer lol ty Jacko.
    I used the links you both sent me to check the PCB and gasket etc previously, everything seemed in good order, No oil quite clean, athough i gave it a good scrub out anyway and changed the gasket. I thought i had sorted it till now.
    I hope with the air pressure releasing, whilst playing around with the Air Intake Flap Actuator (AIFA), that this is the source and end of the problem.
    I have booked it in for Tuesday to have the AIFA stripped, fingers crossed. Frustrating stuff!
    Jul 2011
    catterick
    Thanks guys,
    I used this the last time, to which i thought would fix the problem. The PCB seemed ok, with no oil etc present. I changed the gasket and gave it a good scrub out anyway.
    I hope with the air pressure sound coming from the Intake Air Flap Actuator (AIFA) when poking around, is finally the source of the problem.
    I have booked it into the garage for Tue to get the AIFA stripped, fingers crossed this is the culprit.
    Jacko i moved it to the trouble shooting section TY
    Jul 2011
    catterick
    sorry for the double answer, thought it didnt go on doh
    Jul 2011
    catterick
    £640 pound lighter - new egr valve, air actuator. two days and the dreaded light is back on!!!! rrrrrrrrr same fault code P1125.
    Snapped
    Oct 2010
    Darlington
    ****** Hell. I wish I had seen this earlier. I am Darlington and could have given you guidance and it would not have been anything like £600 as most of it you would have done yourself.
    http://vectra-c.com/forum/showthread.php?t=142503
  1. Fitting a Swirl flap actuator
    By jay w in forum Engine & Drivetrain
    Last Post: 17th May 2012, 06:41
  2. Intake Air Flap Actuator
    By rickylennan in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2012, 21:32
  3. Swirl flap actuator
    By jofenan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 21:01
  4. Swirl Flap actuator
    By M20 RUM in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 21:51
  5. swirl flap actuator?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 15:47
air flap actuator for 06 jaguar s type
