Thread: I really need help
    Regular Member tommythomson12's Avatar
    Mar 2011
    Rochdale - North-West
    Default I really need help
    Right i hope you guys can help me with this please. Could anyone tell me the difference with a TWIN PLUG INJECTOR RAIL and a single plug injector rail for my vectra c cdti 150. I need a new rail as mine isn't that well. But i have been looking at some and both of these (double and single) seem to be used on my car over the years. Can i use any on my car, ?? i thought that one might be a upgrade over the years. To me they both look the same and when you go on ebay or any on the web they both say they are for the z19dth engine which is mine and for the year of my car aswell 2005.
    I hope someone can help me with this
    Nov 2010
    Warrington
    Hi,
    I'm not sure, but, I'd suggest there are two types because: At some point maybe 2006; the high pressure fuel sensors was moved from the left hand side of the rail - it was incorporated into the high pressure fuel pump. Therefore, two rails, one with a sensor and one with the left hand end capped.
    HTH
    bb
    Mar 2011
    thanks now all i need to do is find the right one for my car. Mine is the one with twin plug.
    Mar 2011
    And so does that mean with me having the twin one it has any difference to my car and does the h-p fuel pump is better than what is on mine
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    never heard of any bother with any HP fuel pumps on the cdti.. so cant see it being that, can see it being a cost saving exercise though
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    May 2011
    lancs
    some twin plug ones on fleabay £100
    Mar 2011
    cheers pal. They are £300 at Vauxhall
    Nov 2010
    Warrington
    Arrrgh, OK - The capped end on later models use to house the fuel pressure regulator - left hand side. It must have been this that was moved to the HP pump. The fuel pressure sensor is on the right hand side.
    You've not said what's the problem with the rail. Have you disturbed any unions on it recently? Do the sensors checkout ok? Any leaks?
    bb
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Damaged the thread
    May 2011
    lancs
    update mate someones not long put one on fleabay for £57.50 thats including p&p twin plug one too out of 07 vec cdti
