Thread: Turbo actuator rod length?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Turbo actuator rod length?
    Hey guys, ive had a problem with my turbo which turns out it was the rod had bound itself tight and wouldnt allow any movement.
    Ive had the vacuum thing off and checked and now its all working fine, i just need to know how i figure out how long the rod needs to be in order to get the best performance from the turbo?
    At the minute the car feels a little down on power, however i have only put the lock nut on by about 4 turns from the shortest setting, when i took it off it was at roughly 6, but when i put it back on at this length i had little power.
    Can anyone advise, haynes was useless?
    Nov 2010
    UK
    No ideas with this one?
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    not got a clue tbj mate, but what engine is it?
    could you maybe contact someone like turbo techniks and seee if they can offer any advise
    Nov 2010
    UK
    Its the 2.0dti.
    And ive read countless online articles but its normally aimed at racing and particular turbo's/engines.
    The engine runs and seems to have more power than previously but trying to clear a fault code at the same time means i need everything spot on.
  1. 2.2dti Turbo Actuator Rod adjustment?
    By Innes in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 05:46
  2. Signum 2.8 turbo wastegate actuator
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 08:22
  3. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  4. Turbo Actuator valve - Squicking Noise - cdti 150
    By digitalinkjetman in forum Engine & Drivetrain
    Last Post: 25th December 2011, 00:29
  5. Turbo Actuator
    By frenchman in forum Engine & Drivetrain
    Last Post: 8th November 2009, 21:19
vectra c turbo rod
vectra dti adjusting wastegate site:www.vectra-c.com
