Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Z22YH Cam Chain Rattle @ 41K Miles??
    Dec 2011
    Midlands
    Default Z22YH Cam Chain Rattle @ 41K Miles??
    All....help!
    Looking for some advice.
    Having owned my 55reg 2.2 Direct SRI for a few weeks now everything has been more or less fine with the car until the last couple of mornings. i did an oil / filter / plug change last Sunday and on Thursday / Friday of this week upon starting the car there is a pronounced rattle for 1 / 2 seconds which then immediately dissappears.
    Am i right in thinking this is the cam chain tensioner? I thought the issues with thses failing early (car only covered 41.5K miles now) had been resolved on the 22YH engine?
    Assumng it is the tensioner how quickly is it likely to fail? Am i safe to run the car? Cant see it being anything that i have caused as a result of the service? Engine running nice Mobil 10w40 oil.
    Can someone also give me an idea of what its likely to cost to get this sorted? Assuming there is no point in doing the tensioner without doing the chains at the same time. Is it an easy enough job to do or should i just let dealer do it and be done with it?
    Sorry for all the questions.....
    Steve
    Dec 2011
    Midlands
    Sorry....also rather than using a Stealer for the job can anyone recommend anyone in the Midlands area that might be able to do the job?
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Pm benny mate he is the 2.2 legend
    Full Member Big Sig's Avatar
    Plus he's in the midlands
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep benny's your man. Quick question, when you did the oil change did you check the level with a cold engine or hot, if cold you may have under filled it.
    Sent from my Sony Ericsson Xperia using Tapatalk
    swansea
    Is 10w 40 the right oil.
    Full Member spennny's Avatar
    Blantyre
    Mine does the same , very intermittant, couldnt also be the lifters on a cold morning ??
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by jrh1 View Post
    5/30 is recommended.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Nope 5/30 fully sin
    Dec 2011
    Midlands
    Checked it hot....it's sitting bob on the top line and took the full 5 litres to get it there. Just checked again after 80 mile run home from work and sitting right on the top line.
  1. Z22yh Balancer shaft chain help
    By andrewleighton in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2012, 16:21
  2. chain tensioner z22yh
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2012, 10:47
  3. Timing chain kit Z22YH
    By Sambor in forum Engine & Drivetrain
    Last Post: 2nd September 2011, 10:27
  4. Z22yh With a strange rattle...please help!
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 18th October 2007, 10:17
  5. Z22YH In Need Of A Timing Chain...
    Last Post: 10th October 2007, 10:54
