Thread: changed my outside temp sensor
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Default changed my outside temp sensor
    i seem to have a little problem * i hope little anyway *
    i changed my outside temp sensor as it was giving out the wrong temp.
    it was saying like 34 degree's outside when it was like 10 degrees
    put a new one in and its still NOT changed.. any ideas?
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    anyone?
    Engine : 1.9 CDTi
    Do you have a preface car?
    If you do its probably a corroded connection at the plug by the passenger fog light
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    plug near the passenger fog??? any pics m8.
    thought it was just the plug that goes onto the temp sensor.
    Engine : 1.9 CDTi
    On the preface there is a plug you can uno tahe allows the bumper to be removed with the fogs and temperature sensor still on the bumper.
    This is a facelift picture but the arrow shows roughly where the plug is:
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Nice one, I have same problem. Ill give mine a clean.
    How would be best to clean it.
    Jul 2011
    north lincolnshire
    Engine : 1.9 CDTi
    Scraped the pin on the end I could get to and used a bit of wire to push in and out of the other half.
    Then once done squirted wd40 and contact cleaner into both parts and plugged back together.
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    thanx lee.. just been out to it. but cant seem to undo it.. will try tomorrow in the day.
    i did spray some wd40 on it for now though.. thanx m8
    Regular Member markvec's Avatar
    livingston
    Did it work buddy I got the same issue, replaced the sensor in the middle of the bumper still got the same problem... Telling me it's +15 an I'm scraping the windows
  1. outside temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2012, 14:09
  2. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. 1.8 ECU temp sensor
    By Wacky77 in forum Engine & Drivetrain
    Last Post: 24th December 2011, 22:37
  4. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  5. outside temp sensor.
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2009, 17:03
