Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: holy christ My vectra killed itself please help explain!
    Regular Member IDVAC's Avatar
    Apr 2011
    northeast
    Default holy christ My vectra killed itself please help explain!
    right first off this only happened an hour or so ago and im still a bit messed up but i really need to start asking for help in understanding wtf has just happened to my baby.
    Shes just made a clattering clunk noise then the revs shot up to maximum and i pulled the keys out nothing happened, i jumped out and smashed the battery leads off with a hammer and a bar, nothing happened. i jumped back wondering wtf was going on and would this end, few minutes what seemed like years later, trying to see through clouds of smoke the fire engine turned up by this time my engine was clearly seizing up the sound was nasty then it died, they doused her firery hot engine in water for ages then tried to console me by explaining i should contact my insurance company!
    holy christ i really dont know where to start, i dont even understand what has happened, they said something about the ECU maybe going bad? but with no battery is this possible even? was it mechanical/heat related?
    sorry if i dont make much sense atm ill try to make more sense when i come back to edit this up with a better explanation.
    so to recap series of events were as follows:
    pulled away from idle swiftly but with no problems previously.
    by the time i had started to accelerate away in 1st the car made a noise and started being funny instead of going for 2nd i took foot off throttle and stopped.
    the engine had stalled.
    i started her up, she was making a noise it didnt sound really bad, like a clicky clattering but very light, definatly seemed to be coming from bottom end but that is just the feeling i got from inside car.
    i had to turn the car around because i was in a bad position to attempt to get car back on drive and find out what the hell had happened.
    i turned car round without much problems and drove few metres to the drive.
    she was running rough and clattering by the time i made to half way onto the drive.
    great powerloss so moving it was ridiculously difficult, she is by now starting to smoke a bit out of exhaust.
    i put her in reverse to put it on drive.
    let clutch out gently started moving, suddenly revs shoot up.
    hits red line starts billowing massive plumes of smoke out the back. holds red line.
    pulled keys out nothing.
    smashed battery off nothing.
    Holds redline for 4-5 minutes.
    eventually my baby died
    Help!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Blown turbo
    Seals have gone on the turbo and the car has started to consume it's own engine oil. By starting it again you may have made things alot worse
    Apr 2011
    northeast
    ok thats fair enough, being so close to home was fatal then, if i wasnt literally a stones throw from the drive i wouldn't of bothered i guess, oh well i can take it on the chin happy to know what the hell it was though thanks john.
    Dec 2011
    NEwcastle
    DPF?
    Don't some cars refeed the diesel from the DPF back into the sump which causes it to overfill and eventually gets thin enough to get past the seals and cause the engine to start overrunning on the oil.
    Dec 2011
    Grangemouth Scotland
    As above, I'm guessing yours is a diesel??
    Apr 2011
    northeast
    its a hatchback 1.9 cdti diesel
    yeh but it doesnt have a DPF all hatchbacks dont i was told?
    would someone kindly alter my poor spelling in title if they can be bothered lol should say 'my vectra' not 'by vectra' lol
    Jul 2011
    UK
    Year : 06
    Don't have a dpf
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by IDVAC View Post
    Done for you..
    Hope you get your car sorted m8!
    Engine : 1.9 CDTi
    As said the turbo seals have failed and the engine was running on oil which is why taking the battery off didnt do anything.
    Best way to stop a car when this happens is to stall the car by having your foot on the brake and putting it in 3rd or 4th.
    Apr 2011
    northeast
    yeh it crossed my mind however by the time id done the obvious, keys, battery, forcefully stalling had gone out the window instead confusion and desperation definately kicked in. breathing that crap it was spewing out must of fuddled my brain momentarily...
    thanks guys already starting to feel better, now i know its not some haunted ecu that can run without electric like the fireman was going on about and i know its not some kind of bad fault that could reoccur, so im guessing shes totally fried the fact there is not a drop of coolant left so im just to source a new complete lump, ecu +? and replace the necessary damaged bits? then she will be ok?
    can anyone confirm if spraying my engine bay with a firehose will of knackered anything else that i should consider?
    anyone know of anyone whos managed to get a lump put in an 05 vectra from an accidental damage insurance claim cos surely they cant write it off an engine is not worth the same as the rest of her?
    thanks again
  1. Think I killed my vectra need help
    By zerobug3000 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 22:03
  2. Oh Christ this doesn't look good!!
    By Adz86 in forum The 'Off Topic' room
    Last Post: 27th November 2009, 00:23
  3. Christ it is HOT !
    By Ste in forum The 'Off Topic' room
    Last Post: 22nd February 2009, 15:54
  4. think i might of killed my vectra...
    By Rockster in forum General Chat
    Last Post: 22nd January 2009, 00:28
