Results 1 to 10 of 14
Thread: Cam belt 1.9 CDTI 150
    Sep 2010
    Default Cam belt 1.9 CDTI 150
    Going to change my cam belt, what other items would be wise to do?.. heard something about water pump?.. is this right?
    West
    deffo water pump & any tensioners
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Ditto that.
    [ame="http://www.youtube.com/watch?v=HceHbQbRC_s&list=UUHpfn4i8U2wWalmoIUfOMxw& index=3&feature=plcp"]Vauxhall 1.9 CDTi Timing Belt Renewal Guide.wmv - YouTube[/ame]
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Just bought a cam belt kit (gates with tensioners etc) water pump and aux belt £139 from my local auto store. All fired up to do the job thank you Penfold101 for the video you did.
    Hope fully ambient temperature will rise sufficently soon to allow the deed to be done.
    After reading other threads I am a little concerned that I should have changed the belt earlier!
    Dec 2011
    Northumberland
    Changed belt and water pump today (x2!!)
    The first time the new water pump did not seal and just before I was about to start the car I wondered where the drops of coolant were coming from......They looked like they were coming from an engine mounting bolt at the front of the car but the water was tracking across from the base of the pump. Never had something like this happen before inexplicable really..............
    It all came off again and pump resealed. Could have cried.
    So check the seal on the water pump re-fill system and leave a while before replacing belt etc and check seal is good.
    Other learning points Use a nail fairly large 3" to pin back tensioner for Aux belt tensioner other wise a smaller pin/nail will bend
    Figure out how the belt tensioner works as adjusting it is a bit tricky until all of a sudden, you understand how it tension's and the pointer moves to the correct postion!
    I did not drain coolant down just placed washing up bowl under general area and collected about (appx 2 litres)
    The number of different sized fastners is a real pain! 12, 13, 14, 15, 16, 17, 22 mm + torx Male /female and allen/hex what a mixture!
    You need to remove the under tray around 16 small torx screws for access to crankshaft pulley and to jack engine on sump.
    You do not need the locking tools (defo) as long as you mark up as the ‘How to’ and watch Penfold101's video and start putting the belt on from the crank pulley up to the cam shaft then fuel pump and then attach the belt to the tensioner pulley sliding the flat side of the belt over the water pump as the final move.
    But be careful.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Toe-side View Post
    Check out my thread.... http://www.vectra-c.com/forum/showthread.php?t=144725
    Deffo do it sooner rather than later
    Engine : 1.9 CDTi
    Just a note to say they are not 'Torx' but 'Ribe' fasteners (As its a Fiat engine)
    It's nice to have been useful...
    8k miles and mine is still going strong so it must be ok....
    Dec 2011
    Northumberland
    Another school day never heard of 'Ribe'. Filed for future use!
    Had a look at your thread tony-1977...... so close.
    The things I noticed on mine was that the tensioner pointer was pointing well low away from the original setting (belt stretch) and the car had been squeeking/ groaning at tick over in time with engine speed.
    I thought it was the aux drive belt. But when I turned over the engine by hand to set the timing marks the cam belt was squeeking/groaning The plain idle pulley also had strange wear marks/roughness on it. That was with 91k on clock and all standard GM parts from new.
  1. CDTI 150 CAM Belt again :)
    Last Post: 10th June 2012, 16:21
  2. Cdti 150 timing belt
    By John LE in forum Engine & Drivetrain
    Last Post: 4th January 2012, 12:30
  3. cdti 120 belt change
    By xf8u39 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 15:05
  4. cam belt on 3.0 CDTi
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 19:53
  5. CDTi Cam Belt
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 18:21
