Thread: Starter motor help.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Starter motor help.
    1.9CDTi 120bhp z19dt.
    Hi guys. I am still having a problem with the car cranking for a long time before bursting to live and spanner light still on with key turned to ignition but goes out immediately car starts. For those who are not aware, this problem started immediately DMF and clutch were changed. Things suggested and which I have changed so far are glow plugs, injector seals, leak off pipes, fuel and oil filter, new battery. I have just taken delivery of a new thermostat (don't know if that can cause the problem but the old one seem knackered anyway as temp gauge hardly moves).
    Now I am sourcing a new starter motor with part number 55353857 in case the thermostat doesn't sort the problem as some people have suggested the problem could be the starter. The cheapest I have so far is £120 + my old starter (delivered) for a rebuilt Bosch starter.
    Can anyone suggest where/if I can find a Bosch starter cheaper please?
    West
    Is the battery ok... i have heard that a failed dmf can cause the starter to clog up & run slow
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Yes. Battery is ok. Got a new Bosch 5007 with a higher cranking power than the old one fitted and still same problem.
    When you say "clogged up", do you mean the starter can be removed and cleaned out? Sorry if I sound naive.
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Quote Originally Posted by 123rado View Post
    My DMF and Clutch were replaced 5 months ago and my starter had to be done 2 months ago.. Similar probs to you slow start and dont know if you have this but a loud rattle bang just after it disengaged after a start and it was worse when warm.. All is sorted now sweet as a nut 1st turn start every time.. Good luck.
    P.s would not clean the starter up as it may be the teeth on the starter that are worn..
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by shane31 View Post
    +1 for starter motor though I do not have the rattle bang. The only difference is that all those who have mentioned that they had to change their starter after DMF change still used their starter for weeks/months before the starter had a problem but mine started before the car was brought down from the ramp after DMF change. Could the effect have been immediate?
  1. Starter Motor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:10
  2. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  3. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
vauxhall vectra starter motor removal site:www.vectra-c.com
