Results 1 to 10 of 11
Thread: Z22SE & Z22YH Engine Applications
    Default Z22SE & Z22YH Engine Applications
    Hi Everyone,
    Quick question.
    Was the Z22YH engine available in any other Vauxhall platform other than the Vectra C and Signum?
    Thanks for any info.
    sheffield
    Quote Originally Posted by Lean6 View Post
    Hi Everyone,
    Quick question.
    Zafira b, why you ask..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    was also in alfa and a few other car makers cars .......
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Thought you had a SE m8 or are you after the rods and bottom end for Atomx to do his stuff?
    Sent from my Sony Ericsson Xperia using Tapatalk
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Take it the chain went then
    Sorry I haven't replied to this thread, completely forgot with the fun i've been having with my C.
    I've been having issues with random misses and judders. Replaced the CTS and lambda sensors and the miss is still there. Just before Christmas I noticed a really horrible sulpher burning smell.
    This is pointing me to the manifold catalytic convertor. So....i've managed to grab what I think is a bargin; a brand new Lexmaul manifold for a couple of hundred quid (I never replace wear items with standard parts). However on receiving the manicat I have realised it's for the Z22SE/YH Astra G/Zafira application (Hence the question). To cut a long question short, will this fit my Vec C Z22SE? Otherwise it has to be a standard manicat!
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The engine sits the same way in all cars, as in the zorst manifold it at the back so thats fine, if there is a slight difference to could cut and shut it or even the flexi could take it up. The other after market manifold fit Vec C, Astra and Vec B so I cant really see any problems mate.
    Just the person I wanted to see reply.
    I don't mind a bit of trimming to fit, anything to not fit a standard manicat!
    Is there any difference in pipe diameter (as in the 4 branches) between the Vec C and Zafira/Astra? Are pipe lengths different or is it all much the same? I checked on the LMF website and saw they listed the Vec C as a seperate manicat to the Astra/Zafira Z22SE/YH. Wondered why.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The Astra, Zaffy A and Vec B didn't have a manicat, they just had a cast manifold, separate downpipe and the traditional cat under the car. So the Vec C has a totaly different manifold to all the rest, the only one that might be similar is the Zaffy B with the Z22YH.
    I have seen a Vec C with a Z22SE fitted with the same dbilas manifold as the Astra/Vec b, it then had a Landrover downpipe fitted with a sports cat fitted under the car.
    This is Vids old Vec C with the above setup.
    South east
    The sulphur smell is a symptom of your problem, it's not the cause. It's more likely that one or more of the ignition coils is malfunctioning, causing unburnt fuel to enter the cat. If that's the case, then changing the cat won't solve your problems.
  1. z22se or z22yh ecu
    By dahmich in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2012, 17:47
  2. Z22yh/z22se
    By Alansvecky in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2011, 20:22
  3. Z22SE or Z22YH
    By 2.2 Direct in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2010, 00:10
  4. How to tell if its Z22SE or Z22YH
    By Phil2511 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 21:18
  5. z22se and z22yh pic
    By benny in forum Engine & Drivetrain
    Last Post: 21st January 2009, 23:37
z22yh
z22se engine problems
can a vectra c z22yh be supercharged
z22yh engine
z22se and z22yh in performance
Z22yh cts replace
will z22yh maniverter fit z22se
cts 2.2 vectra c
vectra c had a slight burning smell from engine
how quick is a z22se
z22yh fit z22se
